Stock Stryker F27B Elevon Problems
TX
Long Story - but I had a bad crash and had to rebuild. I ended up having to get new electronics (Parkzone ESC & Servos). I had to wait about 2 months for the servos because they were backordered. When I put it all together the elevons do not deflect much up or down. However, when I give a left or right on the stick they deflect much more. It has been a long time since I had a functional Stryker so I don't remember if this is normal. This in A or B mode.
I have jumper 3 on. The rest are off.
My Feedback: (8)
NY
RE: Stock Stryker F27B Elevon Problems
My stryker deflects more for turning than it does for up/down control. have you tried to fly? you might find everything is fine? you want to be in "B" mode for more control throws
NC
ORIGINAL: BILLPAYPML
TX
Well this is a dead issue now. I took it out today and ..... well it is a do over. Crashed and I will need a new fuse....It was wicked.
NC
