C?
C?
I've noted that many people call the stryker, Stryker c. What does the c stand for? Does it mean how new the model is? Are there Stryker a's and b's?
Thanks in advance
Electrolight
Thanks in advance
Electrolight
FL
RE: C?
Well just like in real aircraft you had variants, so to the Stryker.
The first or A version had a 3 piece wing. Then there was a A/B version, new style foam and a much better bird. B/C version was pretty much what you see today, except it came out before the actual so called C version was released. The B/C had the notches for the hinges, the A/B didn't.
So I guess you could actually say the C version now is actually the 4th evolution of the Stryker.
