t28 trogan front gear
CA
Hello fliers,
I recently got the t28 and been flying it every day,very nice flyer to but have a problum with the front landing gear.
with the set screw tightend all the way the wheel still wants to turn left or right if i have a rough landing and will turn and nose over. It steers ok when the gear is streight .Does anybuddy have an idea on how to secure it better so it only turns when i want it to ?
I tried gluy and almost glued it solid and i dont want it solid i love being able to steer it back after roll out
thanks john,happy fling
CA
RE: t28 trogan front gear
I know this may sound dumb, but I had a similar problem- the clip on the pushrod that attaches to the servo inside was not properly secured, so the wheel just flopped around
SD
Mine tracks well. Check the turnbuckle clip attachment to the servo under the canopy. Make sure it is clipped fully on the servo horn, and the rubber grommet is slid fully up over the clip to hold it in place.
CA
hey the mecanizum that makes the nose wheele turn is solid ,its the rod that the wheel is atached to is what moves even when tight thats my problem.........
