GWS Tiger Moth owners...please read.
Gee I never noticed, but my Lite Stick never had those either. For the LS I use as much as the little servos can provide. If you are an experienced flier then this will be no problem, and it won't be overly sensitive. Well at least the LS is that way
Originally posted by Dugster
I just set mine up on the inside hole on the elevator/rudder horns and the outside hole on the servo arm and figured TLAR (that looks about right), and it was..... Never thought about it before.
Originally posted by StarLancer
So basically as much rudder throw as possible?
If in doubt give it about 30 degrees. Not too much to get you in trouble, but you should still have enough control if this ends up being on the soft side. Then go from there.
