ParkZone SPITFIRE, Ailerons/ Motor Upgrade
Hi
I have a ParkZone Spitfire and love it. I have only flown it twice and notice
the aileron throws are at maximum but roll is slow. The servo is glued into
the wing. What have others done to increase throws?
Any links to upgrading the motor to a outrunner for the spitfire?
thanks in advance [&:]
Mark S
Mark S
NY
RE: ParkZone SPITFIRE, Ailerons/ Motor Upgrade
Alum....Like Tubamike said change to the inner most hole at the aileron, you could also use a longer servo control arm to gain more throw....and if your radio/transmitter permits (not a parkzone) you can program increased throw as I did with my DX7.
LICobra
LICobra
