Parkzone f4U Corsair Rtf
#1302
RE: Parkzone f4U Corsair Rtf
zsultan, I used the same approach as squawk.
Bought a piece of brass tubing at the hobby shop that closely fit the strut axle, drilled out the hub of the wheel to fit the brass tube, stuck the brass tube into the wheel so that maybe 1/64" stuck out on the other side, added a little CA glue (optional if brass tube is a tight fit), cut the tube off with about an inch sticking out. I then chucked the wheel/axle in my drill and spun the wheel against sand paper to give it a desirable shape. A small three edge file is then used to file off the extra tubing.
I hope this fixes you up wheel wise. Keep us posted on your progress.
madwebtvscientist [sm=lol.gif]
[sm=cry_smile.gif]
____________________________________________
Modeling Promoting Bog:
http://www.rcuniverse.com/community/...g&memid=266748
Modeling's rendezvous with destiny will surely be unstoppable when something greater than the narcissistic pleasure of an esoteric chosen few is adopted in modeling.
[sm=cry_smile.gif]
#1304
[8D] zsultan, so long as they do the job you are in like flin.
I spent all day trouble shooting my 109s. One simply had a loose servo connection that I didn't discover until I had gone to the trouble of almost completely removing it from the wing. I should have checked the aileron connection first to be sure that was not the problem. I made a lot of unnecessary extra work for myself that could have been so easily avoided.
I finally isolated the erratic motor performance problem to a faulty ESC on the other 109 and ordered a new one from the hobby shop.
Hold a steady course.
[sm=cry_smile.gif]
[sm=cry_smile.gif]
#1305
Hey guys. Has anyone experienced play in the aileron servo? I didn't nottice it until I put the plane on the ground and gave it full throttle with my new zippy batteries. I could notice the left aileron flapping up and down (not by much though). There is only a couple millimeters of play and the other aileron does not move at all and is solid. Ive had 6 successful flights already. Any ideas what to do? Thanks!
#1306
ON, CANADA
Ihave replaced 2 or 3 of those long lead servos over the last few months. It would appear that these servo gears are really easy to strip. They get sloppy at first and then get really rough over time.
Ireplaced them as soon as Isaw the "loose" action in the aileron. It would be a bad day if one let go in flight.
#1308
ON, CANADA
With all the problems have had with the factory servos, next step for me is to change them out for DS-929MG (metal gear digital) from Hobby king... They cost about the same, but you also need a servo extension.
#1309
FL
ok so i flew it alot but havnt in the last 9 months. when we went out to fly today the reciever would only flahs for a fraction of a second then shut off. there was no control and so we came back without a flight. any ideas on whats wrong?
#1310
foehammer, when I had a problem like yours, fresh batteries seemed to solve my problem. Later, after experimenting with larger props, it turned out that I had a marginal performing transmitter. A new transmitter solved my problems.
You might want to check with Horizon Hobby if your adjustments fail to fix you up.
Good luck.
[sm=cry_smile.gif]
Good luck.
[sm=cry_smile.gif]
#1311
Can anyone tell me if the replacement wing comes with new landing gear mount blocks? I put 3" light wheels, had a pretty decent landing, ripped one right out anyway. Used too much ca/kicker putting it in, and lets just say, hand launch only now!
#1312
ON, CANADA
Here is an onboard pervert keychain cam view of an afternoon flight of my Parkzone Corsair..
[youtube]http://www.youtube.com/watch?v=foyQvkAYZoc[/youtube]
#1315
ON, CANADA
My corsair flies a lot more "stable" as compared to a P-51 that I have. the P-51 tends to roll a lot more quickly and can get out of control easier. Makes the flying more fun....
#1316
At what voltage per cell should the speed control shut down the party?
i never noticed any problem, but the reciever was blinking, and the cells read about 3.3/cell.
New to this electric stuff, but I thought it would/should be more than that?
#1318
I tried a fix for re-attaching the landing gear mounting plates and it worked out pretty well. I had pulled them out and glued them back in so many times (not the best at landing) that a lot of foam was missing and there was nothing left to glue the mount to. I used some of that expanding foam in a can that you use to fill holes around pipes in your home. You fill about half the open space where the foam is missing and place the mounting plate in place. You will need something to hold it in place until the foam expands and drys. The foam is very sticky so as it expands it fills the void and glues the mounting plate in place at the same time. Just make sure you are holding the mounting plate in place or the expanding foam will lift it right off the wing. I used a clamp to keep the mounting plate in place until the foam was done expanding and got hard. It seems just as strong as when the wing was new.
#1319
ON, CANADA
The best for this fix is Gorilla or Sumo glue. The Sumo glue expands about 1/2 as much as the Gorilla, but remains white...
#1320
[8D] Denver/Dangaras, interesting discussions. I found it helpful to minimize aileron deflection angles just enough to roll convincingly, and fine tune the lateral balance so that the 51 could be kept from rolling out of an outside loop. The Corsair does not require such careful tuning for easily controllable aerobatics.
My CALL TO GLORY web site shows how to get a better than 1 to 1 thrust to weight ratio with the stock F4U even with main landing gear by using a modified SF APC prop that provides vertical performance as good or better than the 51 that you might find useful.
wxup, excellent idea! I just used a lot of 5 minute epoxy and Baking Soda because I am always in a hurry. With its 2.75 inch diameter wheels located ahead of the wing leading edge my Corsair is my best landing plane. I hope to be able to beat it with my modified flap equipped Messerschmitt.
Any landing you can walk away from is a good one!
CHECK SIX!
[sm=cry_smile.gif]
CHECK SIX!
[sm=cry_smile.gif]
#1321
Hello,
Just wondering if anyone has tried putting in any rudder/aileron mixing and or expo in their Corsair? And, if so, how much did you put and what were the results
#1323
Mad Web TV Scientist:
"My CALL TO GLORY web site shows how to get a better than 1 to 1 thrust to weight ratio with the stock F4U even with main landing gear by using a modified SF APC prop that provides vertical performance as good or better than the 51 that you might find useful."
For those of us who are hopelessly computer/internet/forum ignorant, please tell me how to find this. I would very much like the information. Thanks.
Dave
Dave
#1324
wxup, post # 1247 on our Corsair thread has the url that you can click on to bring up the prop section of the CALL TO GLORY web site. The unique cowling/prop combination with the F4U provides great sounds that I have not been able to duplicate on any other airplane/prop combination.
The Corsair is a fabulous airplane. Once I develop the kind of skill necessary to fly and land reliably in small spaces with other aircraft, the F4U will get its share of flying time. So far it is the only fighter that I have flown and landed successfully on the small flying site next to my house. My GUNFIGHTER "enjoys" (?) the distinction of crashing on landing attempts 100% of the time so far!
Try not to develop landing/small flying field phobia like I have successfully done. Remember, it is simply a matter of mind over matter. Now If I can only figure out a way to follow my own suggestion everything will be just right.
madwebtvscientist [sm=cry_smile.gif] [sm=lol.gif]
#1325
Hi. I'm new to flying (three weeks) and bought a mini super cub, a T-28 and a Corsair. Actually, I used to fly pipers and cessnas (the big ones) but haven't been an active pilot for ten years. And the truth is these are a lot more fun than the real thing. Anyways, I graduated from the mini and now I'm flying my Trojan. The Corsair is in Mexico at my vacation campo so that I'll have stuff to do there when not fishing and I don't have to tote it back and forth. I'll probably order a 109 pnp today and may also get a 2nd Corsair to fly at home. On to my question. I want to install larger wheels on my T-28 and my Corsair. I saw several references in your posts about larger wheels but I didn't see the actual product name or number. I want it to still look scale but be easier to land on grass and in the desert (Mexico). I'm hoping the wheels are a simple swap and fit on the same wire gear. I'm also researching camera systems. I want to get some good video with the Corsair while it strafes the beaches of the Sea of Cortez.
