Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
Newbie Basic info
Reply
Old 05-13-2003, 04:29 AM
Gitano
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Newbie Basic info
hello
i just wanted to know what else do i need, i'm about to buy GWS basic flight pack , reciever, battery, 2 servos 1 speed control... so my question what else do i need for my airplane, the most basic equipment and the cheapest, also have battery charger...so any help wil do..
thanx
Gitano is offline
Old 05-13-2003, 06:37 AM
darenm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That sounds about everything you need. It all depends on the plane. You may need building tools, but as far as stuff for flight, your good to go.
darenm is offline
Old 05-13-2003, 01:34 PM
Gitano
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well i was thinking on doing a small scrach plane, but i don't know which motor/prop should i use, i think brushless it's kinda expensive, also is GWS a good idea for for electric motor or is there any other good brand
thanx...Estuardo
Gitano is offline
Old 05-13-2003, 02:49 PM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For smaller planes, such as park fliers, there is no reason why you need to go with brushless. The price difference is very signifigant at this size. When you get into larger projects, then the difference between brushed and brushless gets small enough that it makes sense to go brushless. Replacing a brushed motor on a park flier amounts to a few dollars, but when you're talking $30, $40, $50 or more for a large brushed motor, you don't have to replace too many of them before brushless becomes the cheaper option.
When you look at an electric, you have to look at the entire power system, that is, motor, prop, gearbox AND battery. You can't forget the battery. Without the battery, the motor/gearbox/prop are just ballast. All your power comes from the battery.
Your question about which motor/prop to use is impossible to answer without additional information. Yes, GWS motors are fine for electrics, as long as you design a plane that these motors can propel through the air.
Matt Kirsch is offline
Old 05-14-2003, 02:05 AM
Gitano
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well thanx for the adittional info , on the motor, i was planning to convert a free flight rubber powered Cessna 180 into R/C i think i wont need too much power but my main concern is weight cuz dose airplanes aren't too big, if no i'll probably do my one plane very light slow flying maybe 30" 35" of span...
Estuardo
Gitano is offline
Old 05-14-2003, 11:58 AM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ball park figures
Hi Eduardo,
If your 30"-35" span plane is going to come out at under 10oz ready-to-fly then a geared GWS IPS motor would suffice. If its going to be around 12oz you could use a geared GWS IPS Dual motor. Above 12oz you need to start looking into the geared GWS 300C class of motor. As a rule of thumb, you need a sustainable static thrust about 1/2 the weight of the aircraft. www.aeromicro.com has useful tables giving amp draw and thrust for all of the GWS motor/gearbox/prop combinations [the figures given are rather optimistic, but they'll give a ball park idea of what you'll need].
Hope this helps, Cheers, Phil
Dr Kiwi is offline
Contact Us Archive Advertising Cookie Policy
