plane size, weight, motor used
MN
Hello All: I am building a flat foam f-22 pusher type plane. The wing span is 29", 36" long, and about 20-23oz battery included. My question is. I will be using a bp 2212/6 with 200+ watts electric motor and want to know if the "size" of the plane will work with this motor? I have used this motor to push my other planes including my styker, 48" wing etc. This plane just look bigger. Also prop used will be a 6x4 apc. This motor has taken my other planes to 85mph clocked at 18-20oz. Thanks for your help.
RE: plane size, weight, motor used
Try this site:
commonsenserc.com
They have a simple fill in that will direct you to motor/battery/prop for this plane and any plane. It worked well for my Piper Cub and changing to a outrunner motor. You can check your motors ability to what they suggest.
commonsenserc.com
This calculator should also be able to help you:
[link]http://flbeagle.rchomepage.com/software/webocalc_0.9.0/webocalc.html[/link]
AK
Short answer is that your power plant will push your plane around but not likely at the same speeds as you have been seeing in lighter birds. It is well within the thrust range for that motor (Assuming you are using a 30 amp Speed controller and a 20c or higher capacity battery.)
Please post a photo of your plane.
BP A2212-6 Brushless Outrunner Motor Item: 6 of 28
No. of Cells: 2 - 3 Li-Poly
5 - 7 NiCd/NiMH
Kv: 2200 RPM/V
Max Efficiency: 75%
Max Efficiency Current: 14 - 22A (>72%)
No Load Current: 1.4A @10V
Resistance: 0.045 ohms
Max Current: 28A for 60S
Max Watts: 220W
Weight: 51.5 g / 1.82 oz
Size: 27.8 mm x 31 mm
Shaft Diameter: 3.2 mm
Poles: 14
Model Weight: 300 - 100g / 10.5 - 35 oz
Propeller: Volts (V): Amps (A): Thrust (g/oz): Power (W):
APC 6 x 4 E 7.4 V 13.2 A 338 g / 11.9 oz 98 W
APC 5 x 5 E 11.1 V 20.9 A 329 g / 11.6 oz 232 W
A powerful high RPM motor for high-speed flying wings, prop jets, or other planes up to 100 grams (35 oz) using 2 or 3 li-poly cells. Can also be used on helicopters up to 700 grams (24 oz) with 3 li-poly cells. Manufacturer recommends a 7 x 5 prop on 2 cells, and a 5 x 5 or 6 x 4 prop on 3 cells. We suggest propping for around 200 watts continuous power. Expect to pull 18 to 20 amps on 3 cells with a 5 x 5 prop. Use with a 25 amp or greater ESC. An excellent higher-powered replacement for Speed 400/480 motors in park-flyer sized prop jets and flying wings.
5 - 7 NiCd/NiMH
Kv: 2200 RPM/V
Max Efficiency: 75%
Max Watts: 220W
Poles: 14
