Compatible plane with 7.2V 600mAh battery pack
TX
Hi,
I have a GWS E-Starter, and due to it, three battery packs of the same type - 7.2V 600mAh NiCd. These are the ones made up of 6 AA cells in a row.
Can anyone suggest some other Electric ARF's that I'd be able to carry on using the same battery packs.
Adam
PS. Yes this is a repeat post of the one I put in the Electric general discussion, hope to find an answer in one of these two boards.
Adam
Within the GWS line, Beaver, Slow Stick. The warbird series will fly on the packs, but you'll have to build lite and take a little more care flying 'em as it'll be a tad under powered (make sure packs are freshly charged). The Zero will require a different pack configuration, but you packs should fit P-51 and the ME-109. If you can re-time your GWS motor or upgrade to the EPS-350C when it's available, the 6 cell packs would be plenty fine.
TX
Thanks for the reply, do you know of any others? I was particularly wanting to make a bi-plane, something like the Sig Bristol or Wattage Sopwith Camel.
