PicoStick/Litestick dihedral
A bit of help please on this side of the pond. I have a GWS Picostick/Litestick and all the web sites recommend putting dihedral on the wings to improve the flying,but not how much. Can anyone help please?
Mick,
Well the wing mounts DO give the right amount of dihedral but the problem is that the wings can flex too easily so the wings have a tendency to "droop". Most people attach a thread from each wing tip and bring it to a central "mast" inthe middle to just hold the wings up.
If you haven't already found it then http://www.nyblimp.com/litestick.htm is an INVALUABLE resource for anyone building/flying Lite/Picosticks
Cliff
Cliff
I originally flew my Pico Stick J-3 without and it didn't turn as well as I thought it should. I used some monofilament fishing line and the TLAR method. (That Looks About Right). I didn't have to use a mast. Just pulled the wings up. That did the trick. I guess I brought them up about two inches a side. Try several different settings and see what you like.
Many thanks Gents,
I had been on the site Cliff mentioned which is were I picked up the advice about dihedral.
Now all I need is for the wind to drop, might have a go at kite flying in the mean time!!!! :-{)
