possible v-tail configurations?
NY
just wondering if anyone knew of any v-tail configurations i could use the slo-v electronics in. or if there is a way to reprogram the stock setup to work as a regular elevator and rudder? any tips, and links or even pics would be greatly appreciated, chris
NY
RE: possible v-tail configurations?
also im considering using either a bi plane or flying wing design, for materials im planning on using foam board. not sure if that helps with anything. chris
VA
Nothing magical about V-tails they function just as normal rudder and elevators. I have a few of them in my foamy designs both upright(Beech Bonanza) and inverted V. To get the right movement just orient the tail so one of the V's is like a normal vertical rudder. The movement is the same left rudder gives left, right gives right elevator is as normal.
You do however need a mixer either in the transmitter or the aircraft. If your not using ailerons then elevon mixing works also when hooked to the tail feathers. It just puts the rudder for turns on the same stick as the elevator/aileron instead of the throttle/rudder stick. Again no big deal .
Pete
Pete
NY
i kinda get what your saying but the issue im having is trying to use the stock setup just scratch build a new plane all together, but for it to have the normal vertical and horizontal "T" tail setup. the big issue is the slo-v has 2 servos that work together for elevator and rudder, so was wondering if its possible to change it to a t tail setup? im guessing prolly not but figured asking wouldnt hurt, chris
NY
thanks hugger i was wondering about that but wasnt sure if it was for that or something else. ill have to do some research into the uses of that. again thanks, chris
