What kind of paint to use on F27c Stryker????
AB, CANADA
Hey guys Ihave a quick question that somebody could help me with. Here goes:
What kind of paint would you use on a brand new F27c Stryker body? The reason that I'm asking is because I know that some will attack the foam and some might not stick as well. Basically I have bought an extra body and want to paint a cool design on it for when I spank my original one into the ground. These Stryker's are too much fun apart from them CHEAP servos they put in, you would probably agree.
NY
RE: What kind of paint to use on F27c Stryker????
Testors model paint has stuck pretty well, and hasnt reacted with the foam on mine. You just need 2-3 days for total drying, no matter what the can says
NC
I used H2O spray paint on mine. It's available at Wal-Mart stores. Only problem is there is not much of a color selection.
You don't have to do this, but before I sprayed the paint on, I sprayed the foam with 3M 77 Super adhesive which is also available at Wal-Mart.
One the glue dried up well, I then sprayed it with the paint. I think the paint sticks better this way.
