parkzone trojan paint job went to s*@%
NY
ok so im not pointing the finger at any certain person, but i was given advice on what to use for painting my trojan and it turned out looking like hell. at this point i dont even want to fly it, just curious as to what i can do to remove the layers of paint that are making it look so terrible. first off i wasnt told wether to sand the surfaces or to use any type of adhesive remover to remove any excess glus left behind from the decals. second i was told that the krylon h2o paint was foam safe but if thats the case then why am i getting bubbles in the foam and why is it showing extensive orange peel in the paint? i took all the proper steps that i was given to paint this bird and now i feel as though ive been lied too. im seriously doubting the level of experience i am getting from this forum considering my trojan looks like s@#% now. please any help as too how to undo this horrible paint job would be appreciated. at this point all i can think is to buy an entire new fuse and wing and not bother painting it, chris
NY
RE: parkzone trojan paint job went to s*@%
well i managed to salvage the trojans paint. took a days worth of sanding and peeling off the blue, but i did finally get the bird painted. ill have some pics up this afternoon after i get the final details finished. its gonna look sick once its finished. chris
ON, CANADA
You can sand the plane fairly smooth. Go to the hardware store and buy some spackle ( kind of like plaster) and patch any divets. then sand smooth. I paint foam with water acrylic paints and airbrush but recently i have been getting lazy and just brushing it on. This way i can go to the dollar store and but paint.
hope this helps
hope this helps
OH
Krylon H2O is a latex spray paint. That means is is waterbased and yes it is foam safe. That being said it can be a pain to work with. You need to do multiple light coats, you can not try to cover in one coat. Also, being a latex paint, the nozzle tends to clog very easily. The smoother the surface, the better this paint looks.
Personally, I don't care for it.
You should always test out any paint on a test piece of foam if at all possible prior to diving in.
I've always had good success with Testors Model Master paints.
The key for a nice paint job on a foam plane is always to have a properly prep'd(like removing any old adhesive) and smooth a surface as possible, and light multiple coats. (light coat, let dry, light sand, light coat, let dry, light sand, etc...) The light sand step with a fine grit paper is optional. You may also have to do a primer step if you are attempting to go light over dark.
MS
I have read that the paint in which you used for your Trojan is foam safe, but I believe that the propellant may have caused your result. It can be done but with multiple light coats.
