Slow stick CG moving
PA
Had the same problem........wondered why the trims were changing all the time........I used a dab of RTV Silicone at each point where the plastic touches the fuselage stick. I would guess that "Goo" or any similar adhesive would work as well.
Duie
[email protected]
Duie
[email protected]
Thanks for the reply. I ended up putting very small screws through the wing and servo mounts to keep them in place. Had great luck flying once my COG and trims stayed put. Unfortunately there is a small bend in the prop shaft and the wheels are damaged from crashing prior to the fix.
