Go Back  RCU Forums > Electric Aircraft Universe > Park Flyers & Backyard Flyers
Reload this Page >
Has anyone had a lipo go bad for thier Mini Cub?
Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
Old 04-26-2009, 08:06 PM
JesseJames
Default Has anyone had a lipo go bad for thier Mini Cub?
I was doing preflight check. When I checked to ensure the motor and throttle were working, I got very little prop speed. I then heard a hissing so I removed the battery. It got very hot and ballooned up. It no longer works. I only had about 6 flights on it. My guess is this is not a lipo normal life span. Anyone else had this problem?
Old 04-27-2009, 05:30 PM
cjg
cjg's Avatar
Default RE: Has anyone had a lipo go bad for thier Mini Cub?
With a LIPO that puffing and release of gas can be very dangerous. It is usually caused by overcharging, damage, or a short.
You are lucky you didn't have a major fire.
Contact Horizon about a replacement. Do not attempt to use the battery again.
Check out Youtube for lipo fires and you will see the need to be cautious.
Old 04-27-2009, 07:50 PM
RedGN
RedGN's Avatar
Lipo's in general can go bad without warning. There is no definite time or reason. There is no quarantee that a lipo will last for a predetermined period of time.
If it goes bad discharge it and get rid of it. Yes descharge it.... Down to zero or as close as possible.
Just from experience. I had bought over 30 lipo batteries from different manufacturers ( Labels on the battery ) ranging from $10 to $130. So far 3 went bad just sitting there for about a week. One Evo Flight Power battery($120), One Mystery 2400 mah 3s ( $25 ) and one no name ( $20). There were about 3 batteries destroyed from crashes ( one in a lake and shorted battery) and the rest are still good. It's been about two years now with multiple charges on each.
I find these batteries are unpridictable to when they will go bad.
Hope this helps
Old 04-27-2009, 07:57 PM
Mr. Mugen
Mr. Mugen's Avatar
Same here. I discharge them and then soak them in a salt water solution for 2 weeks then discard in the trash. You did get lucky indeed. I have never had one catch fire personally but have had the swelling happen on about 12 occasions so far. Do not send it back! Call horizon and they will send a replacement.
Kevin
Old 04-28-2009, 08:09 PM
JesseJames
I don't think it was a charging issue. I flew it for several minutes, mostly gliding. Two days later went to fly without recharging, should have had plenty of juice. hissed and balloned up during preflight check.
Old 04-29-2009, 06:41 PM
Tyler P
ORIGINAL: JesseJames
Did you leave it connected to something by any chance? Over discharging will damage them quite easily.
