Micro SpeedWing RTF Now Released!
CO
Like the Mini SpeedWing©, the Micro SpeedWing© is a fast, agile and highly aerobatic flying wing, only smaller, lighter, quicker, stronger, and maybe even more fun! Now available in RTF form, the Micro SpeedWing is ready to go right out of the box. The power system includes a Fiegao 4100kv 12mm Brushless Motor, turning a 3x3 prop on 2-cell 350mah batteries. The Micro SpeedWing© flies at 58 m.p.h. with the stock power system and can fly as slow as 10 m.p.h. for close in flying. The Micro SpeedWing climbs like a rocket and can reach speck height in only a couple of seconds. With maximum control throw the Micro SpeedWing© does 6+ barrel rolls per second. But, with smaller throws even a novice will find the Micro SpeedWing an easily controllable and surprisingly stable flyer.
The Micro SpeedWing is a very small wing that you can take anywhere, you can even fit it in your briefcase! It is the perfect “take to work” plane to fly on those lunch breaks or to stop by the park on the way home. Although this kit isn’t recommended for beginners because of its high speeds and agility, once you master the basics of flying R/C planes, anyone can handle this plane.
- 16" Wing Span, the Smallest Production Wing to Date!
- 3 oz. AUW with 2s 350mah LiPolys
- Specialized Blended Airfoil
- Extremely Fast and Agile, And Can Fly Slowly
- Extremely Stable
- Truly in a class by itself
- Extremely Stable Flight, "Flies On Rails"
- Flies Like a Much Larger Wing
- Small Enough to Fit in a Briefcase
- Carbon Fiber Leading Edge and Spar
- Flies at 58 m.p.h. with the Stock Brushless System
- Nearly Indestructible, 100% EPP Wing with Carbon Reinforcements
Equipment Included in RTF:
- Fiegao 4100kv 12mm Brushless Motor
- Castle Creations ThunderBird 9 ESC
- Blue Arrow 3.6 gr Super Micro Servos
- Corona 4 DSP Full Range Receiver (AR6300 Spectrum at additional cost)
- 2-cell 7.4V 350 mAh Li-Poly Batteries
Acer
http://speedwing.net
- Extremely Stable
Acer
