im going with 11.1 volts on a 300...prop size?
i ordered the kokam 3 cell super high discharge li-poly cells because i want to go completely vertical. i know the motor wont last as long and frankly i couldnt care less. i need that power. any suggestions on a prop size for this voltage?
Are you going to gear it or go direct drive?
What plane are you powering it in.
I would think that 4:1 gearing and a 10x7 prop should get you in the ballpark on a 16-20oz plane, but you'd have to experiment with prop sizes to find which one suits your application best.
Good luck.
Jason
Good luck.
Jason
HI
I'm more than sure you'd need to use a 3S2P to run a S300. If you have a 3S 1020 mah, you'll get 4.8 amps continuous from the pack. As long as the motor or motor/gb doesn't draw more than that you'd be Ok. The Etec 3S 1200 mah would give you a safe 7.2 amps continuous.
usually that li-poly battery is equal to about a 10 cell pack which should really over-amp your present 300 gear ratio/prop combo...... you might try going 1 diameter size smaller prop in an attempt to pull the new expected amps down to present ammount
