electrifly pt-19 hand launch
RI
hi just recently finished a electrifly pt-19 fairchield.has anyone tried a hand launch the field i will use is a little rough for ground takeoff thanks
RI
RE: electrifly pt-19 hand launch
do you think with such small wheels in short grass i should remove landing gear .not sure how monocote would handle a belly land
you should be ok with both.butif the grass is short give it a try! once you touch down when landing give up elevator so it doesnt tip forwardto much.or go tobig parking lots on the weekend when its empty.
