GWS A-10 rectifying a bent wing
My GWS A -10 has a bend in the left had outer wing panel, giving it more dihedral on the left hand side than the right.
The bend starts about 3 inches in from the tip and includes the aileron, which I have not yet seperated from the wing.
Any clues on how to take this unwanted bend out of the foam wing, without weakening the structure, would be appreciated.
NV
i heard lightly warming it with a blow dryer will work. i read that about the gws mustang or spitfire or something- everybody was saying that the two halves of the rudder were bent to the right or something and one guy used a hair dryer to warm it up then bent it back to where it is supposed to be. you might want to read that thread.
The bent wing has been corrected.
Used a Heat Gun on low setting.
Lightly clamped the TE of the wing to a table (not the wife's "best" table) and carefully applied heat back and forth
across the wing while a buddy held the wing in the correct position.
After a while (trial and error) it assumed the correct shape.
