Aerobird 3 Throttle Cut off by Itself problem
VA
Hi! I just got an Aerobird 3 from ebay whit the problem already on the receiver. It cut off the throttle by itself after 3-4 sec.
My questions is Does somebody out there know what component should be replaced on the receiver to get it work properly again? I'm don't want to buy another esc/receiver.
Thank you in advance.
RE: Aerobird 3 Throttle Cut off by Itself problem
how good are the batterys? sounds like the batterys are bad to me
Is this the orange plane with a rubber nose ?
VA
Yes, it it the Hobbyzone Aerobird 3 the orange one with the rubber nose and the batteries are good, I have 3 of these 8.4V batteries and I have the same problem with all 3.
I had the same problem with an Aerobird 3 I bought from Hobby Zone. I RMA's the plane, and the replacement plane had the same problem. The third plane was fine. I believe the gentleman from customer support said it was the controller circuit board.
Tom
