P-51 Ultra Micro battery choice
AZ
I have found out that the 250 mah 3.7 v battery will work with the Ultra Micro P-51. You have to do some modifications to your charger and plane to make the battery fit, but works like a champ. It extends the flight time a lot. On the plane, just take a dremel or exacto knife and widened the area for a the bigger battery. You have to do the same for your charger as well. I think it actually flies better with the bigger battery. It makes it more stable especially in windy condiitons.
AZ
RE: P-51 Ultra Micro battery choice
None at the moment, if you buy the battery, just widen it enough to make it fit. I will try and take a pic later.
