Anyone Know Standard Stryker F27C Motor Amps and Watts
Hi,
I am trying to find out the specifications for the Stryker F27C motor, specifically the safe maximum amps and watts on 3S LiPos.
I've tried Google and different RC forums and only found the following specifications:
Number of poles: 6
RPM/Volt (Kv): 1881
Diameter: 29mm
Length: 37mm
Shaft diameter: 3mm
Does anyone have the safe maximum amps and watts for the motor using 3s LiPos?
Thanks for your help.
Fly4Fun,
Wayne
Number of poles: 6
RPM/Volt (Kv): 1881
Diameter: 29mm
Length: 37mm
Shaft diameter: 3mm
Fly4Fun,
Wayne
RE: Anyone Know Standard Stryker F27C Motor Amps and Watts
Hi,
I've been told the Stryker motor has the same specs as the E-Flite series 6 motor so I looked it up on their web site. The following is the specs from the web site. Can anyone confirm if this is the same as the Stryker motor specs? Thanks for your help.
Specifications For E-Flite Series 6 Motor
Type: Motor
Size: 400 / 480 upgrade
Overall Length: 36mm (1.40 in)
RPM / Volt (Kv): 2000
Voltage: 7.2–12
Resistance (Ri): .06 ohms
Idle CUrrent (Io): 1.75A @ 10V
Continuous Current: 26A
Cells: 6–10 Ni-MH/Ni-Cd or 2–3S Li-Po
Speed Control: 35–40A brushless
Weight: 80 g (2.9 oz)
Shaft Diameter: 3.17mm (1/8 in)
Bearings or Bushings: Two 4 x 10 x 4mm Bearings
MaximumBurstCurrent: 32A (15 sec)
Overall Diameter: 28mm (1.10 in)
Recommended Prop Range: 5x4 to 6x5.5 direct drive or 10x6 to 12x6 with 2:1 to 3:1 gearbox
Type: Brushless inrunner
You Will Need
35A–40A brushless ESC
6- to 10-cell Ni-MH/Ni-Cd or 2–3S Li-Po
5x4 to 6x5.5 direct drive or 10x6 to 12x6 props with 2:1 to 3:1 gearbox
Type: Motor
Voltage: 7.2–12
You Will Need
TX
The stock ESC on the F-27 was the 25 amp E-FLIGHT. In the past year they have moved up to the 30 amp version found here:
http://secure.hobbyzone.com/search/EFLA1030.html
JC
JC
