parkzone servo install
Hi all I'm new to RC and I have a simple question about servo installation.
I got a parkzone p-47 BNF and I've been flying it pretty well (I think). I wanted to install flaps and then later retracts. I got the long lead servos from my LHS. In the manual it says to use doublesided tape or hot glue. Is tape strong enough? I'd think that it'd let go with time/forces to hold those flaps down. What about CA? is there a reason not to use CA? Also the servos come with the um "lever parts" attached. Do i just find the travel (about 180*) of the servos then center the "lever/arm piece" on the servo(90*)? -Brian |
RE: parkzone servo install
ORIGINAL: dalgrim Is tape strong enough? I'd think that it'd let go with time/forces to hold those flaps down. What about CA? is there a reason not to use CA? If you use CA on a foam plane, be sure it is foam-safe CA. Regular CA may attack and melt the foam. To make it easier to remove the servo in the future, wrap the servo with a layer of tape so that you are gluing to the tape rather than directly to the plastic case of the servo. I have not used CA for mounting servos, but I have used hot glue, which works well, in my experience. It holds firmly, yet you can usually remove the servo if necessary without damaging it. Hot glue works even if the mounting surface is slightly curved, whereas CA needs a flat surface for best results. ORIGINAL: dalgrim Also the servos come with the um ''lever parts'' attached. Do i just find the travel (about 180*) of the servos then center the ''lever/arm piece'' on the servo(90*)? - Jeff |
Thanks for the info! I never thought about removal, I'm new and haven't learned that crashes are a "When" not an "If". I'll be going the hot glue route.
It's often said that every R/C plane comes with an expiration date, but you never know when that will be. It might fly for years, or its next flight could be its last one!
Even if you never crash your plane, you may one day want to retire it, remove the flight gear, and use the components in another plane. - Jeff |
Awesome advice, Jeff! I wanna buy a P-47 now just to install the flaps and retracts, never mind flying the noble beasthttp://www.rcuniverse.com/forum/js/f...sn/biggrin.gif.
ORIGINAL: jdetray It's often said that every R/C plane comes with an expiration date, but you never know when that will be. It might fly for years, or its next flight could be its last one! Even if you never crash your plane, you may one day want to retire it, remove the flight gear, and use the components in another plane. - Jeff |
