Flyzone DHC-2 Turbpo Beaver
Question for any of you who have this plane. I have about 5 flights on this plane. I find that i have to fly it at almost full throttle with a 2200 3s battery to get any speed at all. Also, as soon as I throttle back, the plane acts like it almost is putting on brakes; its speed immediately drops way back. Is this a common experience of others with this plane?
Thanks, Terry |
1 Attachment(s)
Prop reversed? Concave side should face direction of flight.
What is the voltage, and voltage sag under load? What is the motor Kv? What are the expected and the measured rpm? Prettig weekend ;) Ron • Without a watt-meter you are in the dark ... until something starts to glow • • e-flight calculators • watt-meters • diy motor tips&tricks • Cumulus MFC • |
