Set up twin engines,tracker 111
WI
Hi;.Trying to set up my Twin star.:Lost everything when updated!Engine 1 on #3,engine 2 operateswith the dial on rt #7?Trying toget mix to work no luck.Tried couple times setting 3 as master and 7 as slave no luck!Then somethingbout setting to +or- to 0-100?.Is there something about assigning that #7 to a position?I know this worked in the past can't figure what I am doing wrong??Thanks!!
