Pristine Updated Brison 4.8 with Factory Mufflers.
Rare. As new with Factory Mufflers. Updated with Small Plug CM-6 Mod and RCXL CDI Ignition. New Carb Kit. Owner's Manual. $515 Tony 678-687-3268 |
Can you tell me what is the dimension from plug cap to plug cap so I can see if this engine will fit inside my cowl? |
Originally Posted by scaleflyer50
(Post 12510740)
Can you tell me what is the dimension from plug cap to plug cap so I can see if this engine will fit inside my cowl? Tony |
Sure. I should have placed that info in the Ad. It's 10 1/4 Inches with the RCXL plug caps installed. The Small Plug Modification saves almost an inch.
Tony |
