ROTOmotor 35Vi-35cc with muffler and ignition free prop drill jig.
These are new in box, not used
* DISPLACEMENT 34,8 ccm * STATIC ENGINE THRUST 9,5 kg * BORE 39,5 mm * WEIGHT 1480 g * PISTON ROD2 × NEEDLE BEARING TORRINGTON * CRANK SHAFT2x BALL BEARING * IGNITIONPROCESSOR CONTROLLED |
