PowerBox PowerPak 5.0X2 5000mAh PRO Li-Ion Receiver Battery
Brand New in box, Free shipping, 1 Pack.
For more info send a PM or mail to [email protected] FEATURES Integral charge / security electronics (PRO version) Can be charged using mains PSU or 12 V adapter (PRO version) Integral voltage monitor using external LED (PRO version) Automatic discharge to storage level (PRO version) Packs assembled using the latest generation of high-current Li-Ion batteries Two different versions: ECO and PRO Two different output voltages: 8.4V and 12.6V For use as receiver power supplies or turbine batteries Integral balancer Integral charge socket Rugged case protects cells from external influences Packs are held securely in the standard mounting frame with quick-release latch Batteries can remain in the model for charging Easy, swift battery swapping Economic cell exchange service TECHNICAL DATA Battery type LiIon Capacity 5000mAh Nominal voltage 7.4V Final charge voltage 8.4V Charge voltage 10V - 17V Weight 235g Weight, mounting frame 8g Temperature range, discharge 0°C to 60°C Temperature range, charge 0°C to 40°C PACKAGE CONTENT PowerPak Mounting frame 1x MPX/JR connection lead 1x MPX/MPX connection lead 4 rubber grommets 4 brass tubular spacers 4 screws Operating instructions in german and english |
