TurboHeader Muffler for 4 Stroke Engines
THE TURBOHEADER MUFFLER
FOR SAITO, OS, MAGNUM AND OTHER FOUR STROKE ENGINES The TurboHeader Muffler's patented design increases the peak performance of your engine by 200-300 RPM, and that's just the beginning. Its sound attenuation chamber brings out a fantastic tone that is sure to grab the attention of your fellow modelers. The TurboHeader is designed as a compact alternative to the stock muffler and will fit inside most cowlings. It can be adjusted to any angle when coupled with the 90 degree adapter. Custom machined to exact tolerances from high quality aluminum for strength and durability. The new design is welded, heat treated, and clear anodized. The muffler comes fully assembled and installs in minutes. "NOTHING SOUNDS LIKE A TURBOHEADER" Model TH10x1A (Weighs 1 ounce) Fits: Saito .50, .56, .62, and 100 twin Model TH10x75A (Weighs 1 ounce) Fits: Os 40-61 FS, Magnum FS 52 &61, Enya 52 & 80 Model TH12x1A (Weighs 1.5 ounces) Fits: Saito 91, 1.00, 1.15, FG 14 & 17, 182T Fits: OS 90/91FS, FS95V, ASP FS91, Magnum FS91, TT F91S (requires RCS11x12S Adapter) Fits: OS110A (requires RCS127x121S Adapter Model TH12x1B (Weighs 1.5 ouces) Fits: Saito 65, 72, 80/80A, FG-14, FG-17, 182T Fits: OS FS70, 72A, 81A, ASP 80, Magnum FS70, 80, 160T, Thunder Tiger F75, , & F911S (requires RCS11x12S Adapter) Model TH13x1A (Weighs 1.6 ounces) Fits: Saito 1.25 & FG 20, 21 (no performance increase) Model TH14x1A (Weighs 2 ounces) Fits: Saito 1.80Fits: ASP 180 (Requires the RCS147x141S Adapter) Fits: Magnum 180 (Requires the RCS147x141S Adapter) Model TH14x1B (Weighs 2 ounces) Fits: Saito 120, 150, & 300T Fits: Magnum XL120, Thunder Tiger 130, ASP 120 & 130, OS 120FS (Requires RCS147x141S Model TH15x1A Fits: Saito FG30, FG 36, FG 40 Fits: OS 200 (Requires RCS16x15S Adapter) |
Muffler
Will need muffler and adapter for OS 110 A. Thanks, Fred
Hi Fred,
We have them in stock. It is best to order direct from our website at www.rcspecialties.net Regards, Jim |
