Futaba 16SZ Air Radio with R7008SB Receiver
This Radio is Brand new , FREE Shipping USA
For more info send a PM or mail to [email protected] throwing in a free new futaba external voltage input cable 16SZ Transmitter - 16-Channel Digital Proportional RC System 2-Stick, 16-Channel, FASSTest 2.4 GHz System (01004355-3) (01004356-3) FEATURES FASSTEST SYSTEM: The 16SZ transmitter has adopted the bidirectional communication system "FASSTest". Data from the receiver can be checked in your transmitter. FASSTest is a maximum 16 channels 2.4 GHz dedicated system. COLOR TOUCH SCREEN LCD: T16SZ has an HVGA 4.3 inch, full-color backlit LCD touch screen. The screen is transflective which enables both indoor and outdoor visibility. S.BUS2 SYSTEM: By using the S.Bus2 system multiple servos, gyros and telemetry sensors are easily installed with a minimum amount of cables. MODEL TYPES: Multicopter. 8 swash types are available for helicopters. 7 types of main wings and 3 types of tail wings are available for airplanes and gliders. Functions and mixing functions necessary for each model type are set in advance at the factory. NIMH BATTERY: The 16SZ is operated by a 6.0 V/1,800 mAh NiMH battery. SD CARD (SECURE DIGITAL MEMORY CARD) *NOT INCLUDED: Model data can be saved to an SD card (SD: 32MB - 2GB, SDHC: 4GB-32GB). When T16SZ transmitter software files are released, the software can be updated by using an SD card update. EDIT BUTTON: Two edit buttons are provided, and the operating screen can be immediately "Returned" to the HOME screen during operation. Setting operation can be performed easily by combining this button with a touch sensor. VIBRATION FUNCTION: Selects a function that alerts the operator to various alarms by vibrating the transmitter in addition to sounding a buzzer. SPEECH FUNCTION: A function is equipped which allows the system to provide telemetry data audibly. This function can also be utilized with commercially available earphones. CONTENTS YOUR T16SZ INCLUDES THE FOLLOWING COMPONENTS: -T16SZ Transmitter (Air Version includes ratcheting throttle, Helicopter Version includes smooth throttle) -R7008SB Receiver -HT5F1800B NiMH Battery and Charger -Switch Harness -Mini Driver *NOTE: The battery in the T16SZ transmitter does not arrive already attached to the battery connector. Please connect the battery connector before use. TRANSMITTER SPECS TRANSMITTER FREQUENCY: 2.4 GHz band SYSTEM: FASSTest18CH, FASSTest12CH, FASST MULT, FASST 7CH, T-FHSS, S-FHSS, switchable POWER SUPPLY: 6.0 V HT5F1800B NiMH battery FREQUENCY BAND: 2.4 GHz RF POWER OUTPUT: 100mW EIRP RECEIVER SPECS R7008SB SIZE: 24.9 mm x 47.3 mm x 14.3 mm 0.98 in x 1.86 in x 0.56 in WEIGHT: 10.9 g 0.38 oz POWER REQUIREMENTS: DC 3.7V~7.4V VOLTAGE RANGE: DC 3.5V~8.4V |
Hi Sir ,
is the receiver included ? thanks . |
Originally Posted by luismgarzon
(Post 12553633)
Hi Sir ,
