Futaba R6014HS Faast 14 Chan Receiver
This is the Futaba R7014SB 2.4GHz 14 Channel FASST/FASSTest Receiver.
FEATURES S.BUS and S.BUS2 operation Standard PWM and S.BUS output ports High voltage (up to 7.4V) Diversity antennas may be mounted in different axis for best reception FASST Multi; normal mode or high speed mode Multiple optional telemetry sensors may be connected to display data on the transmitter Easy binding button One year limited warranty through Hobby Services beginning at date of purchase INCLUDES R7014SB 2.4GHz 14 Channel FASST/FASSTest Receiver SPECIFICATIONS Modulation: FASST, FASSTest Channels: 14 Power Requirement: 3.7 - 7.4V Voltage Range: 3.5 - 8.4V Dimensions: 1.5 x 2.0 x 0.6" (37 x 50.2 x 15.9mm) Weight: 0.73oz (20.8g) Never Been crashed,removed from a flying aircraft,only has two flights, Removed because have changed radio manufacturers |
