90mm all inclusive Setup HET/Jetfan/Castle
Flown not blown! Used 6 flights and decided I didn't like the foamy jet it was in. Motor: HET Typhoon 700-60-1865 Fan: JetFan 90 V2 The JETFAN 90 is a high performance fan custom built in Austria, featuring a 9 blade rotor made up of precision hub and GRP molded blades, this rotor is one of if not the toughest 90mm on the planet! Housing features carbon fiber shroud with GRP molded stator assembly. Castle Phoenix ICE 100AMP ESC Castle 10AMP BEC FREE SHIPPING TO AL 50 States. |
