RCU Forums
RCU Forums (https://www.rcuniverse.com/forum/index.php)
-   Marketplace (https://www.rcuniverse.com/forum/forumdisplay.php?f=560)
-   -   Tamiya Pajero Metaltop Wide Almost Ready To Run (https://www.rcuniverse.com/forum/showthread.php?t=11650531)
jkdv8 06-22-2018 06:46 PM
Up for sale is a gently used Pajero metaltop wide from Tamiya.
It is equipped with an Axial AE-5 speed controller,
RC4WD 65 turn motor w/ Robinson Racing pinion,
Traxxas 5ch TQi receiver and controller,
Controller operated winch via the modded 3 position switch, retract/stop/extend.
Controller operated G.T. Power 27 LED light kit complete with tail(4), brake(4), reverse(2), turn signals/hazards(6), operated by the 2/4CH switch, and the headlights/taillights (2/4), bullbar fog lights(2), side mounted fogs(2) and top mount lights(5) are operated by CH5. The light kit also offers many different customizable options including brightness, flash rate, and 7 light show modes.
Both diffs are locked but the extra spider gears to convert back to an open diff for front are included.
All it needs to run is batteries. It is wired for Ni-Cd/Ni-MH but it is 2S/3S LiPo compatible and a low battery alarm is included, just need to switch out the plugs and change some settings.
Everything you see in the pictures will be included;
Truck
Topcad alloy 8 hole wheels in black with 3 sets of offset adapters 0, 5, 10mm. They are used and missing one screw.
manual for the truck,
light kit manual,
winch manual,
speed control manual,
and Axial light bucket kit manual;
unopened decal set,
4 original tires (one as spare on back),
Rancho style shocks for lift (not installed),
original bumper,
original tin can motor w/ pinion,
20T robinson racing pinion sealed (16 tooth installed),
voltage sensor,
temperature sensor on motor,
rpm sensor for telemetry (not installed),
unused light buckets from the Axial light bucket set,
and the phone pad kit for the controller.
Paypal preferred but will accept money orders.
Shipping responsibility of buyer.
