Futaba 16SZ
Selling my Futaba 16sz transmitter and including a 6014HS 14 channel receiver Compatible with FASSTest, FASST, T-FHSS and S-FHSS protocols Full telemetry compatible 4.3" LCD touch screen 10 programmable mixes S.Bus servo programming editor S.Bus trainer port 3-axis gyro support 30-model memory with 15 character naming 3-axis gyro support Swash and throttle mixing V-tail mixing Adjustable servo speed AFR/DR AFR curve mode (3) AFR curve point (17 points) Idle down Logic switch 8 flight conditions Throttle cut Voice message/audio earphone jack Micro memory card slot Software updateable Up/down/integral timer Free online software upgrades Lap timer memory Stick calibration 180° antenna rotation and 90° angle adjustment Multi language (9 languages) EPA One year limited warranty through the Futaba USA Service Center beginning at date of purchase Airplane and Glider Features; 13 wing types 3 tail types 2 rudder types Flap setting Aileron differential Aileron to camber flap mix Aileron to brake flap mix Aileron to rudder mix Airbrake to elevator mix Rudder to aileron mix Camber mix Elevator to camber mix V-tail Ailevator Winglet Motor mix Airplane Specific Features; Rudder to elevator mix Snap roll Airbrake mix Multi engine Glider Specific Features; Butterfly mixing Butterfly to elevator Trim mix 1 Trim mix 2 Helicopter Features; 8 swash types Pitch/throttle curve Pitch/throttle curve mode (3) 17 point pitch/throttle curve Acceleration Throttle hold Swash mixing Throttle mixing Pitch to needle mixing Pitch to rudder mixing Gyro sensor (3) Governor Condition hold Hovering pitch Hovering throttle Swash AFR Swash setting Swash ring Throttle limiter Multicopter Features; Gyro Telemetry Features; Receiver battery Temperature RPM (magnetic and optic) Altitude GPS Voltage Current Servo Voice (English, German, Japanese, French) Data logging INCLUDES Futaba 16SZA Transmitter with 6.0V NiMH rechargeable battery 6014HS 14 channel receiver REQUIREMENTS Servos of modeler's choice (analog servos cannot be used in FASSTest12CH mode) SPECIFICATIONS Transmitter; Transmitting Frequency: 2.4GHz band System: FASSTest18CH, FASSTest12CH, FASST MULT, FASST 7CH, T-FHSS, S-FHSS, switchable Power supply: 6.0V HT5F1800B NiMH battery RF power output: 100mW EIRP Receiver; Receiving Frequency: 2.4GHz FASSTest system Power Requirement: 3.7 - 7.4V (voltage range 3.5 - 8.4V) Current drain: 75mA External voltage Port: 0 - 70V DC Size: 0.98 x 1.9 x 0.56" (24.9 x 47.3 x 14.3mm) Weight: 0.38oz (10.9g) Antenna Length: 5-3/4" (146mm) |
