sold
The plane is sold but I have no idea how to delete this ad. Thanks RCU for making this so easy!
Ziroli P-40
Originally Posted by kork
(Post 12444666)
Built this last winter and only a dozen flights on it !
Fiberglass fuse, Robart rotating retracts, solid rubber tires and aluminum rims. Desert aircraft 85cc engine with a pitts muffler and Mejlik 3 blade prop with a aluminum 6-1/2" spinner All Hitec high voltage servos, PSP 34 ounce tank,Tech areo IBEC, Jem fuel Dot, Taildraggers wire harnesses for easy hook up, Pulse 3200 batts.Loaded with panel lines and rivets. Klass Kote paint and Callie graphics, I installed all of the best parts in this bird and everything is new to the build. The plane flies incredible, I am selling because of a large radial engine purchase.. Must see and will be at the Owatonna NAMFI and the Fond du lac the following weekend. Can deliver to Air venture in Oshkosh Wisconsin In a couple weeks. Pm for more pictures and questions. |
Go to RC scale builders and read my build thread.
Korks p-40 is the heading under ziroli |
Damn..what a plane!
