Jetcat P-60 SE
Jetcat P-60 SE Propane start just back from George at Jetcat with the 25hr service cycle completed.
Comes with all the accessories in the picture P60-SE Turbine Engine, 13 lbs Thrust, by JetCat Thrust: 13 LB @ 165,000 RPM. Weight: 1.87 LB, incl. Diameter: 3.25 inches. RPM Range: 50,000 - 165,000. Exhaust gas temp.: 580°C -690°C. Fuel consumption: 8 oz per/min at full power. Fuel: Jet A1, 1-K kerosene. Lubrication: approximately 5% synthetic turbine oil in the fuel |
P60se
Hi Nick, I will offer 900 right now, thanks!
