ROTO 85 FSI - two cylinder four stroke gasoline engine
* DISPLACEMENT 85 ccm
* STATIC ENGINE THRUST 12 kg * BORE 39,5 mm * WEIGHT 3 000 g * PISTON ROD 4 × NEEDLE BEARING * CRANK SHAFT 4 x BALL BEARING NSK * INGNITION PROCESSOR ROTO * FUELGAS + OIL MOTUL 710 1:40 * RPM 1000 - 5800 * 2 BLADE PROPELLER 25-26/10-12 * 3 BLADE PROPELLER 24/10-12 * |
