2013 new eight fold axis aerial vehicle HY-118 officially listed
Hao-118 can be realized quickly folded, folding process 5 minutes to get carbon tube 25MM, such as shaft diameter 1450MM Wheelbase 1180MM mounted 25-inch paddle. Imported from Japan, high-strength carbon fiber tube, state-of-the-art design and excellent workmanship. The large wheelbase is very stable aircraft during aerial.
Trace 3 dihedral design, that can be appropriate to increase the stability of the aircraft in hover and flight, and not because the dihedral angle is too large loss of flight efficiency, while the arm slightly upturned, reducing the arm into the shooting screen possible, the whole aerospace aluminum alloy metal connectors, high strength, light weight, resistance to deformation, high-strength design, suitable to carry all kinds of SLR and medium-sized camera equipment, such as 5DII 5DIII, FS100, RED Scarlett, eight axis ultra-high security, loss of a group of power in a timely manner can still ensure the safe conduct of the flight, fully compatible with the the DJI system, a direct replacement for the S800 body removed from the nervous flight concerns.HY-ANGEL-118-V2 large truck professional aerial eight-axis rack with power suit aerial machine
Section price of the rack + power systems set!
Price includes:
Package: retail price of $3089;
Package II: the retail price of $3252;
Package three: the retail price of$3415.
HY-Angel-118-V2 rack * 1
2, customized version of the professional multi-axis disc motor 48 * 8
Customized version of the professional multi-axis disc 48 + motor * 8
Customized version of the professional multi-axis disc 51 motor * 8
Motor series with, the price is subject to change according to customer choice
3, professional multi-axis platinum gold 40A ESC * 8
4, positive and negative carbon fiber paddle pair
5, connections and plugs and other accessories
6, the above price does not contain the tripod and head, sold separately, strongly recommend the company's HY-ANGEL-HH3 head with the models perfect.
Detailed list:
HY-Angel-118-V2 rack * 1;
Professional multi-axis Platinum Edition 40A ESC * 8;
Motor series:
Customized version of the customized version of the professional multi-axis disc 48 motor * 8;
Customized version of the customized version of the professional multi-axis disc 48 + motor * 8;
Customized version of the customized version of the professional multi-axis disc 51 motor * 8;
Carbon fiber oars series:
1447 Carbon paddle * 4;
1555 carbon paddle * 4;
1775 carbon paddle * 4;
Package: rack + custom 48 power suit +1447 the paddle +40 A platinum = $3089;
Package II: The the rack + customized version of the 48 + +1555 paddle +40 A power suit platinum = $3252;
Package III: rack + custom 51 power package A platinum paddle +40 +1775 = $3415.
Yunnan Hao Yu model HY-Angel-118-V2 eight-axis aircraft Profile:
HY-ANGEL-118-V2 aircraft the eight eight axis rotor design layout, each machine arm has 3 degrees dihedral angle, the arm can achieve rapid folding, folding is very convenient to carry, covering very small. Can take off and land vertically, automatically fixed-point hovering unmanned aerial vehicle systems. Can be applied to commercial aerial photography, film and television aerial, search, communication, monitoring, reconnaissance and other tasks. The body is made of high-strength carbon fiber material and military grade aerospace aluminum after machining centers precision machining, not only high structural strength and weight is lighter than other similar products.
The HY-ANGEL-118-V2 design load of 12 kg, can carry REDEPIC, C300, FS100, FS700, 5D3 and other professional video equipment.
HY-ANGEL-118-V2 can be manually operated by remote control flight, can also be done automatically hover flight control comes with GPS positioning system, automatic return function, but also by the dedicated ground station computer navigation system autopilot flight (another optional). With manual remote control, auto-hover, autonomous flight and other flight mode.
HY-ANGEL-118-V2 supporting WKM flight control and navigation system integrated three-axis accelerometer, three-axis gyroscope, magnetometer, pressure altimeter and other high-precision sensors and advanced control algorithms, allowing manipulation becomes very simple, even if you have no remote control flying experience, but also within a very short time to learn and use.
HY-ANGEL-118-V2 has an excellent safety design, with a variety of protected mode, in order to ensure the flight safety of the aircraft.
Such as the use of the optional Data Radio and image transmission systems, and ground station system,
BVR flight and real time image transmission.
As an electric unmanned aerial vehicle, she was only a very low power consumption, the support of a group of on-board battery life time can be up to 20 minutes or more (depending on the task load and ambient conditions), and the replacement of airborne the operation of the battery is not more than 30 seconds to complete, and convenient.
Features:
Flight modes: manual remote control, auto-hover, autonomous flight;-load take-off weight: 6000 g; General Task Load: 10,000 g;
Maximum hanging deadweight: 14,000 g; maximum cruising speed: 10 m / s;
Flight altitude: ≤ 1000 m (relative height);
Manual remote control, automatic hover Control radius: 1000 meters;
The autonomous flight Radius: 10 km;
Power supply: 22.2V lithium battery;
GPS positioning accuracy: ≤ 2 meters (5 stars);
Normal take-off and landing wind speed: ≤ 4 level;
Thanks for your support professional aerial truck, folding axis Welcome to wholesale, Order http://item.taobao.com/item.htm?spm=a1z10.1.w11-3536282503.2.K6nx8I&id=18334806456
The focus, so the pursuit of a professional! Hao Yu is willing to work with you into the future! We sincerely thank you for your support! Contact QQ: 2294349119 E-mail: [email protected] concern Taobao: http://shop67554797.taobao.com Website: http://www.hhljaviation.com
