Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news or have a new product announcement you may post it here.
NEW PWM Meter & Low Voltage Cutoff Switch!
Reply
Old 11-30-2017, 01:04 PM
ServoCity
ServoCity's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default NEW PWM Meter & Low Voltage Cutoff Switch!
ID:	2246590Click image for larger version
ID:	2246591Click image for larger version
PWM Meter - $19.99
Need to know what PWM signal your receiver, robot or servo controller is sending? Simply plug in our PWM Meter to see a readout of the PWM signal in microseconds (µsec). If you wish to pass that signal on to your servo or device, just plug into the other set of header row pins.
ID:	2246593Click image for larger version
Low Voltage Cutoff Switch - $19.99
It's important to protect your LiPo batteries from being drained below 3V/cell and our Low Voltage Cutoff Switch does just that. This switch has 3 modes; 1S, 2S or 3S and it simply passes the voltage on from the battery to the load (motor controller, ESC, servo controller, light, etc.) until the battery meets the cutoff voltage.
Whether you are powering a microcomputer like a Raspberry Pi, a microcontroller like an Arduino or an RC vehicle, our Low Voltage Cutoff Switch takes away one of the main challenges of working with LiPo batteries.
ServoCity is offline
