ignition system for any kinds of conversion gas engine
we are offer the new ignition systeme that for any kinds of 2 or 4 stock conversion gas engine .
this ignition use 4.8v-6v and can handle 7.2V mix votage. all including spark plug , sensor and other parts that you need for conversion .
Melody models Inc
Tomy Shen
[email protected] [email protected]
Melody models Inc
Tomy Shen
RE: ignition system for any kinds of conversion gas engine
yes , it's can be down , but way you want to conversion .91 4C engine to gas? just like the CH-ignition company said . we recommand at lest 1.20 size . if the size under 1.20 2C , I think nitro engine are more good then gas . by the way . if you want to conversion any engine . you should draw a holl on the shift and put an small megnit inside . that make the sansor know the time to fire the spark.
What about system reliability and RF propagation? New ignitions systems entering the market will have to be able to substantiate their ability to produce reliable results without producing more RF "noise" than we now have with existing systems. If everything checks out well, I would consider your system for a couple of my aircraft.
