MT-57i BULLY GAS ENGINE
Long strock and high torque design for 3D fly .
SPECIFICATIONS: Automatic advancing electronic ignition
Performance... Output Power: 6.3HP at 7200rpm
Idle Speed: 1300 rpm Maximum Speed: 7800rpm
Dimensions... Displacement: 57cc
Bore and Stroke: 44mm 38mm
Compression Ratio: 8.6:1
Weight: Engine - 1650g
Requirements... Fuel: 2C Regular Gas mixed 30:1 - 50:1
Propeller: 22-10, 23-10,24-10
Ignition Battery: 4.8 to 6.0 Volts >=1200Mah
Replacement Spark plug: NGK BPMR6F
Configuration... 2Cycle air cooled
Walbro membrane pump carburetor
