OMP 540FF Landing Gear?
My Feedback: (25)
Starting to build the OMP540FF-What is the lightest landing gear for this bird.I know many use the Dubro,anything else out there and where to purchase.Thanks in advance.
RE: OMP 540FF Landing Gear?
I had a set of Jeff Williams carbon fibre gear on my Extreme 330, they were light and very tough. I liked them so much I got another set for my OMP. I've also used the DuBros, and they're nice, but the carbons sit a bit taller and win out in the looks department.
D
D
The stock wire gear bent and was heavy. It also interferred with muffler placement. I have the DuBro on mine (black version) and it has held up to a year of heavy flying. CF gear or krazy legs are your only other options.
I like the krazy legs - I recently bought a pair for an Aeroworks giant profile, and I have a CF pair for a Sledge in the works, but I haven't flown either of them. My impression is that the Krazy legs will be tougher, but the CF lighter (and cooler).
Leonard
Leonard
I need to start a poll of all our profilers out there regarding the OMP FF540P gear. The Kit comes with prebent 5/32 gear which has some good advantages over profile gear. It is lighter (I've weighed it against the nylon gear) and it gives in all direction thus putting less wear and tear on the fuselage. The Profile gear looks better and doesn't bend as easily but can break and tear up the fuselage more on hard landings. So what do folks prefer: the wire gear or say Tetherite gear?
Mike
Mike
IN
edgeman55-RCu, I sell the Carbon fiber gear for 40 size profiles and have several sets on the OMP edge 40 size. If you have a pair of Carbon fiber gear that breaks for no reason I will replace them. I have found that most fliers say the gear breaking has usually saved a fuselage. They are the lightest gear you can attain and have incredible strength. If you are interested email me at [email protected] and I will provide additional information. Jeff Williams
My Feedback: (27)
MI
I guess I could use a carbon gear on mine -the wire works but I could use some nose weight ,as when Im inverted It does consecutive outside loops!and needs about a quarter stick of down to fly level
The CF gear wasn't available when I built the OMP edge, but I have a set for the Sledge that's in the works.
Leonard
That's ballistic Ballistic1! You probably have the record for the furthest aft cg on the OMP Edge! Do you mean 1/4 stick up just to hold inverted? Giving it down will help it pull tighter outside loops. I'm beginning to think folks would like an upgrade on the stock wire gear?
Mike
Mike
My Feedback: (24)
I've been using the Wire gear for probably over 100 flights. It has saved my Fuse 3 or 4 times, but it seemed in the beginning I was always having trouble keeping the fasteners attached to the gear through the Fuse. The Tiny screws would just pull out after a few harrier landings. I've since moved to some "heavier" wood screws to hold the gear on, now the wire will bend before ripping out. If/When I build my next OMP I would use some hardwood around the gear regardless to give those screws a little bit more to bite into. I can tell they are just biting into the hardwood plate around the front of the plane because my fuse has slightly separted on the bottom of the plane.
My Feedback: (27)
MI
AFSALMON- yes 1/4 stick of back elavator for level inverted flight -very unnatural!!!but-hovers forever and the plane does a awsome inverted flat spin w/ just rudder & throttle -actually climbs, it is however difficult to land -as you have to push to keep it comming down
I actually intended to put my YS 63 on it but I had a MVVS 49 collecting dust so thats what I put on and hence my severe aft C.G. problem
ParticleMan,
The best way to secure the gear is to run 4-40 bolts and nylock nuts all the way through the fuse to the other side. Wood screws will definately pull out given the dumb things us profilers do with these planes.
Ballistic1, so what happens if you add up elevator when doing the flat spins? If it already climbs then I guess it will go ballistic! ha ha. Sounds like a handful.
Mike
Mike
I am building my edge now and am getting ready to vocer the fuse what should I do up front if I am goingt to use the dubro landing gear of possiably the cf gear I was going to put a hardwood block up front is that enough
thanks
thanks
My Feedback: (42)
TX
You don't want a hollow fuselage in between the gear mounting legs.
Make sure there is some hardwood or hard balsa behind the sheeting.
Just plan ahead for whatever type of gear you might be using.
My Feedback: (28)
I have 2 OMP 540 have dubro white nylon profile .40 size gear. I made my own axe shafts using 2- 10-32 machine screws and 4 10-32 nuts that you can get at the hardware store(much lighter than the dubro style). Then I went with dubros foam ultra light wheels 1-3/4" This makes a great combo. Just make sure you use thread lock on the axle nuts. I have used both planes all year no issues!
I would recommend installing battery pack and receiver aft behind the hacthes instead of in the front wing compartments. This keeps the weight more aft allowing you to ballance the airplane by moving the engine further out on the motor rails. After building the two airplanes both ways I found that the craft performs better with the weight in the rear.
My Feedback: (27)
MI
Mike
Well Mike I tried and it pops out of the spin, so
I put 5.5 oz of stick on weight on the nose . after flying I found that while inverted it still climbs -about a 1/8 stick of back elevator is needed for level flite
and what I found is strange is that it hovers and torque rolls so much better now -even in the wind! I am at a loss to explain this as I allways thought a aft C.G.
made hovering and torque rolling easyer??
also noticed very little roll coupling when in knife edge so I think the weight will stay on or put a heaver motor on .
I have to tell you that THIS is the best profle I have ever flown !
Frank
Pro Bro 272
Mike
Frank
Pro Bro 272
