Assembly thread on Extreme flt edge
#226
RE: Assembly thread on Extreme flt edge
did anyone figer out how to cut down on the vibration using the saito .82 I start building tommaro any help would be great and pics thanks
#227
TN
I just put one of these together myself. It is maybe the best made plane I've ever seen. The only thing I didn't particularly care for was the heat shrink for the clevises. I have my CG an inch back from the spar. This thing is awesome in knife edge flight and waterfalls.
#228
TN
Much better than the goldberg eh. I was flying a goldberg extreme before this too. My EF came in at 10 oz lighter than the goldberg.
ORIGINAL: DFWS
Assembly Mods!!
I added GP Venus wheel pants for more of a scale look!!![8D]
Steerable tail wheel from CG Extreme 330 profile ARF kit
all Dubro 4 - 40 hardware.
Changed the canopy color to black to look a little different
and match my CG Extreme 330 profile.
Assembly Mods!!
#229
IL
What is everyone coming out with weight with the Saito .72 on it? Mine came out at 4.7lbs. I was hoping it was going to be lighter. I can only see maybe getting rid of 2oz with a different receiver and battery pack.
#230
IN
Craig, mine weighs in at about the same weight with a YS63 and I am totally pleased with its performance in all flight regimes. Your new carbon fiber gear will look great on it too, love mine. Jeff W.
#233
TX
Hi All,
I have a question. I took my newly assembled EF Edge 540 with Saito .72, all new radio and servos, Hitec Electron 6, Hitec 475HBs all around, and an HS85BB on the throttle. The Saito is new so I was going to run a tank through and fly. I believe the stock tank was leaking air because the stopper screw seems to have stripped so engine was running pretty rough. What I noticed was that the HS85BB was constantly moving the throttle(surging back and forth) with no change from the transmitter stick. I have read all about the HS81s not being up to snuff for this application considering the vibration, that is why I got the 85. Does it sound like the servo is bad or am I going to have to get a mini-digital? []
#234
I dont think you'll need a digital servo to fix your problem..
If your throttle servo is bad replace it with a standard servo. You will have to open up the cutout where that servo goes but that istn as big deal.
#235
My Feedback: (16)
NJ
Before you get the new servo...
Make sure the metal throttle pushrod is not rubbing against any metal surfaces.
Try a new servo extension if you are using one.
#236
TX
Thanks for the ideas. I never thought about the servo extension.
Wayne, I hate to put a standard size servo in because I am balancing at about 1/4" behind the spar. I was hoping to come out about an inch. Instead of the stock tail wheel, I used a Sullivan and a 1" Dubro wheel but I guess I probably should have used the stock setup as it places the actual wheel back further. I moved the engine as far back as the carb would allow. Battery is as far back in the wing as I can get it. Any other ideas for balancing without adding tail weight?
#237
Yours is balanced pretty much were mine is..
I dont think the additional weight of a standard servo up front is going to make that big of a difference.
If it does, a tiny bit of tail weight will get you back to where you were.
Too many people IMO make the CG on these planes a bigger issue than it needs to be.
#238
IL
I have a Saito 72 on mine also. I had to bite the bullet and add tail weight. It took about 1oz. This is my first 4 stroke. I couldn't believe the power with it on this plane. I have only about 10 flights on mine and the motor still is running very rich. Has unlimited verticle and does great climbing inverted flat spins. I would just add the weight and try it. The only other thing would be to move the battery to the outside of the fuse like some others have done.
Later,
Craig
Later,
Craig
#240
WI
My edge construction is stalled at installing those darn aileron servo rods. I have Hitec 425's in the wing, but can not get the rods to line up with the control horns. What do I need to do to get these rods installed? I read the post by williams, but that's not working for me. my control horns are not very long. I hope I do not need to get new control horns becuase my LHS does not carry longer ones like the Dubro ones and I really want to get this brid in the air this weekend. I have been working on this for a week (only can work at it 15 min at a time with a new baby in the house). any help is appreciated.
#242
My Feedback: (9)
TX
Snyperx, take a look at a construction thread I did on this plane in the User Product Review forum, post num. 23. I used Dubro heavy duty servo arms and Dubro ball links at each end and the push rods came out dead center of the slots. You have to use longer servo arms than stock to line em up.
#244
My Feedback: (56)
VA
Fellers,
What's the definitive choice for prop selection on the YS .63?
I'm getting ready for my maiden (hopefully this weekend), and I'd like to have an idea of what props to try out on the YS.
Thanks!
-Wayne
Thanks!
-Wayne
#246
IN
I have a YS63 on mine, I like the APC 13 X 4W fun fly prop. I tried the APC 14 X 4W and did not like it. The 14 X 4 had too slow of spool time for my taste but the YS will turn it. I run 30% coopers heli fuel. Jeff Williams
#249
FL
running a hs-55 on thr. no problems here-20flights. though i'm running a 46fx, not many vibs coming from this motor!
but i'm noticing alittle slop in my control surfaces! any suggestions? thanks
#250
PA
Here's one that you won't see every day...
Powered by an AXI and TP 4s4p, and is a rocket with unlimited vertical.
It hovers well on a 4s3p too.
Jim!
Jim!
