Pictures! Electric Tacos
#176
My Feedback: (12)
RE: Electric Tacos
And after flying mine quite a bit this weekend, I like the 12X6SF the best....still. Granted, it draws the most amps of any prop I have, and it's spinning 1K past it's redline...but for shock and awe the 13X6.5 isn't near as good. Put 15 packs thru it in Tulsa, the most I put back into one was 1.9A, the lowest voltage at rest when I went to recharge was 11.1V
#177
My Feedback: (19)
RE: Electric Tacos
Chuck, are you using the apc or the gws SF prop. I have a couple gws 12 x 6 I use on the foamy but the prop hub seems kinda small to drill out for the cobri shaft. Now that Ive gotten use to it's vertical it doesnt seem as fast. I assume the 74 tooth spur would be better for the SF.. correct? ( I am using the 72, but have a new 74 to try)
#179
MS
RE: Electric Tacos
nope I already paypaled BPP for a motor and a gear box twas a shot in the dark I hope and im sure I will get it if not Im gonna whoop Chuck
#181
My Feedback: (12)
RE: Electric Tacos
I got one I can let you have until yours gets in if you get into a bind for time. If I'll get another Taco-sized plane done before Nashville, it takes like 2 minutes to swap motors so I can have all the gear in it and just swap motors back and forth.
Why not shoot me an email, Stanooo...
#182
MS
RE: Electric Tacos
I got the Taco framed up waiting on servos and a motor to finish the wing and fuse its at 7 oz all the wood right now wing un sanded I also spar webed the mess out of it im gonna go back and take alot of that out I think the wing wieghed 2.7 now....
I want it under or at 25 so I guess im gonna start trimming and go with the solite
Can sombody tell me if the Lehner comes with a prop adapter if not which one do I need?
#183
My Feedback: (12)
RE: Electric Tacos
The Lehner don't come with jack..but it would be a sorry motor for direct drive..maybe a 4.5X4.5 prop. However, if you put it in a gearbox, it will do better. I like the Cobri 20 gearbox, it comes with a 4mm collet prop adapter.
#184
WA
RE: Electric Tacos
ChuckAuger..........
I really appreciate your taking the time you did, on the comparsions between the different motors, a few posts back.
Very informative.
[8D]
Very informative.
[8D]
#185
RE: Electric Tacos
I'm starting to put together my shopping list for this winter project. I decided I need to have an E-Taco
Looks like I need to buy the following:
Lehner 1020/15
Phoenix 35
Cobri aluminum gearbox 12 tooth SS pinion, 70 tooth spur
Tanic pack:
[link=http://www.tanicpacks.com/catalog/product_info.php?cPath=26_25&products_id=98]http://www.tanicpacks.com/catalog/product_info.php?cPath=26_25&products_id=98[/link]
In an attempt to save a bit of money, would I be able to use these:
Motor: Razor 2500
LiPo packs:
I already have 4 3cell Etec 1200mah packs. Can I just use 2 of them and make a 3S2P pack? I figure the AUW would be around 160 grams. The Tanic pack is 176 grams.
If the LiPos would work, I could probably swing the Lehner motor.
Lehner 1020/15
Phoenix 35
Tanic pack:
Motor: Razor 2500
LiPo packs:
#186
My Feedback: (12)
RE: Electric Tacos
With the lighter batteries and the lighter Razor, it would probably fly on the Razor if you can come in at 22~23 oz. But even a 3S2P Etec pack is only gonna be good for about 18A, that's probably what the Razor will draw.
#187
RE: Electric Tacos
#188
My Feedback: (12)
RE: Electric Tacos
If you already have the 2500, I'd try it. If you have to buy a motor, there's not a lot more difference (if you get the combo from B-P-P... the way he has it broken down, you get the motor for $115 if you had to buy an $85 ESC, or you get an $85 ESC for $65 if you just bought the $135 motor...anyway)
Also, if you have a Razor 2500, you could make a smoking Edgeling, or an Attitude, or that little E Flight Yak..
#190
My Feedback: (8)
AR
RE: Electric Tacos
I got to fly Chuck's Lehner set up on the E-Taco in Tulsa and it was awesome! I couldn't believe the vertical that thing had! I don't think that you'll go wrong with that set-up!
#193
My Feedback: (12)
RE: Electric Tacos
No, I don't have any way to take any video, or get video onto the computer, or host the videos. I have to rely on eye witness accounts! [8D]
And yes, I saw you video. I think your plane ROCKED!! Did you ever fix it??
#194
My Feedback: (8)
AR
RE: Electric Tacos
I'll vouche for the harriers on Chuck's E-Taco. That thing does an awesome slow harrier! There was a slight breeze when I flew it, and if it had been my plane and I hadn't been worried about messing up someone else's plane I could have harriered it sitting still! Awesome plane, Chuck! Thanks for letting me fly it!
#195
NY
RE: Electric Tacos
Ya, it's fixed, then my friend crashed it, then he fixed it, then i the nose broke off in flight, then it was fixed, and right now i havent flown it in about 2 weeks cause it doesnt fly well at all anymore. I should have made it out of balsa.
