Morris Topcap radio set-up
My Feedback: (21)
Alright, I finally got my new battery for my topcap and got the hatch all back together again. Still need to really break in the Saito but it should be okay.
I only have 26 flights on it from 1 week of flying it but I want to see what other flying this plane have set-up.
C of G?
Expo on all surfaces
Are you using maximum throw?
Spoilerons
Rudder to elevator mixing for coupling?
Any information would be appreciated.
Steven
C of G?
Spoilerons
Steven
My Feedback: (26)
WI
RE: Morris Topcap radio set-up
Flew mine for quite a while until I dorked it this spring. Fun plane, but I did have a lot of coupling in KE.
I flew mine with the CG about 1/2" behind the spar.
I was down to almost no Expo on anything. I feel it reduces control feel too much when there is a lot of Expo.
I flew almost at Maximum throw all the time. This is what brought on the demise of the plane - I tried to stretch a glide, but with 3D rates I put myself into a beautiful spin and augured it in. Funny now, but not then
Didn't use Spoilerons.
I ended up with about 12 to 15% elevator with rudder application because of coupling. It helped some, but the coupling has different amounts with different rudder applications so I was always fighting the coupling a bit, but the mixing helped some.
Hope this helps.
Jeff
Hope this helps.
Jeff
Banned
ORIGINAL: Goinstraightup
My Feedback: (21)
Mine knife edges good, but does have some coupling. I think it has a lot to do with the set-up. I want to try spoilerons but with the 9CAP I am having trouble trying to get both ailerons to do it. I can get spoilerons on, then when I do, I cant get them off! I had to completely erase all my settings and start all over. I am using a 6 channel Hitec Electron 6 which is maxed out. Any ideas?
