Bad Boy V2 Build!
#327
RE: Bad Boy V2 Build!
That's great shots, well done to the camera man!!
Man what a field you’ve got there!!
Do you have higher res format of those photos?
Shaun
Precision Aerobatics Team
Shaun
#328
IL
I'll have to check with the cameraman on the higher res photos. I'll also tell him what a good job he did on the picture taking. I had a heck of a time trying to get him to stand behind and off to the right of me to take em.
#329
TX
Sorry in advance for my dumb question. How does the tail wheel stay on when mounted the PA recommended way? It looks like the one wheel collar keeps it from going up to far. When keeps it the other way?
Rob
Rob
#330
NY
ORIGINAL: onemetre
Rob
Rob
#331
TX
I was going to go with the recommended non-steerable method. My preference is to go with the solution that's robust. What do you recommend and how do I do it?
Rob
Rob
#332
NY
ORIGINAL: onemetre
Rob
Rob
www.carolina3d.com
#333
My Feedback: (56)
AL
Hey, have you guys died? Or are you too busy flying the wings off your Bad Boy V2's like I am?! This thing gets better all the time. And, it makes me look alot better than I am at 3D. Anyone even thinking of getting one of these should jump on it while they are still in stock. Maybe Novabill will chime in with a stock status?
#334
NY
STATUS UPDATE.
Only 16 Bad Boys left. They are all red and have been test fit to assure perfect planes. These last planes won't last long, so if you have been thinking about ordering, you better get off your duff
www.carolina3d.com
www.carolina3d.com
#335
TX
What's the preferred method of running the antenna? My preference will be to mount it so the BB can be stored / transported with the wings off.
Rob
Rob
#336
ORIGINAL: onemetre
Rob
Rob
Per the instruction manual. Drill a hole in the rx wing and stick the antenna out through a piece of fuel line tube and attach it all the way over the black cover strap with sticky tape
Simple
Shaun
#337
NY
Check out this video of Kyle flying e-BB #2 this stuff is awesome.
E-FLIGHTLINE is one of our official dealers and you can order through them at www.e-flightline.com
http://www.e-flightline.com/movie.htm you have to click on this link and then right click on the picture of the Bad Boy and save target as...
Enjoy the vid....it's the best BB footage yet!!!!
#338
WA
Good day guys,
Yep we ( www.e-flightline.com ) are very happy to add Precision Aerobatics to the line aircraft we are sell and powering. Here are the specs for our BB.
Specs on the Bad Boy are as follows:
Wingspan 53 inches
Wing area 805 sq/in
AUW 4lbs 9oz
Motor Mega 22/30/2 (gas version is 46 size)
Gearbox Mini Inner Demon 3.5:1
ESC Castle Creations Phoenix 60
Battery pack Tanic 3s2p 4440
Prop APC 19x8 (yep that big)
Static Amp 49.8 amps
If you have any questions please just let me know. Ill post some pix once I figure out how to do thumbnails.
Splash
Wingspan 53 inches
Wing area 805 sq/in
AUW 4lbs 9oz
Splash
#339
Outstanding photos Splash !!
Have you considered one pack setup instead of two?
Also going with smaller prop?
Shaun
Shaun
#341
NY
OK, I had to put it up 99% complete because of the new product release. I'll get the link to the home page and the picture thumbnails working soon.
Check it out. The video page will be up in a week and it'll have 30 or 40 vids on it.
www.carolina3d.com
www.carolina3d.com
#343
NY
#344
I am just about to order my Badboy. And i have a Katana Mini, and was very impressed with the quality of that plane from PA. But what i want to know is would standard futaba s3003 servos be sufficient for this plane, or will i need something a bit better. As im working on a budget. I have the engine a OS 46AX which from what i have seen should power it just nicely.
Cheers Joel
Cheers Joel
#346
NY
Hey all,
We have announced the new name on the rename Carolina 3D threads.
Go here
http://www.rcuniverse.com/forum/m_37..._4/key_/tm.htm
http://www.rcuniverse.com/forum/m_3832308/tm.htm
Go here
#347
I have balanced my badboyv2 and when flown for its 1st time it was rolling left quite a bit to level it i had to add 60grams to the right wing anyone have any suggestions?
#348
You definitely don’t need the 60gr weight
Check for any warp in the ailerons from rear view and use a heat gun to fix this warp if any
Email us directly to: [email protected] and we will help you out if needed
Shaun
Shaun
#349
Which engine?
What engine would best suit the BB:
I have an OS 70 Surpass 4 stroke and an OS 55AX 2 stroke and also a Rossi 40. I know the 70 has been used but does that mean adding a ton of lead in the tail to balance it?
I do have a 46AX but thats in another plane.
