covering the mojo 60
GA
After just two nights of building all I have left to do is build the wing. (yes I know I built it backwards). My question is how do you go about covering the fues?? I mean theres only one stick of wood in the back giving it strength at this point. I am afraid to really move it around much less cover it. Would it be ok to lay it back down on the plans and tack a stick of balsa in the front to make it more rigid while covering, then after covering it cut the stuff back and remove the wood??
My Feedback: (97)
MO
RE: covering the mojo 60
Yes. That is what I do. I stick a piece of 1/2" sq. balsa in the middle and a longer piece on the nose. Just tack it with some thin CA and when you are done covering, twist them out, sand if needed.
