Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Team OMP Presents the Boxxer ARF!
Reply
Old 03-06-2007, 08:54 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Team OMP Presents the Boxxer ARF!
Good morning RCU!!!
Well, by poupular demand, Team OMP is proud to announce the OMP Boxxer ARF!!! No, this is not a "maybe someday" project, these are a "yes happening" project. The airplanes are in production now, and we expect to see planes very soon.
Clean off your work space, find yourself your best 46 to 82 size glow engine (or electric equal), dig up 5 servos and a reciever!
Here we go..........
Soon to appear at www.ohiomodelairplanes.com .
ID:	636227   Click image for larger version
TailTwister is offline
Old 03-06-2007, 08:56 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Team OMP Presents the Boxxer ARF!
The first step involves the obvious time with the sealing iron. Smooth it up, and get set to move on. For my plane, the only part that was noticable loose was the diamonds under the lower wing.
The first real work involves getting the plane ready to set the top wing incidence, if you do not have an incidence meter...
If you do, skip this stuff...
1: To align the top wing without an incidence meter, you will need to create a centerline to work from. The engine mount is set to zero degrees of up and down thrust. The horizontal stab is set to zero degrees as well. To find this centerline, place a long measuring stick down one side of the fuselage, and create an approximate line from the bottom edge of the top motor mount stick to the top edge of the lower horizontal stab mount. You will need to put a piece of blue masking tape under the measuring stick, and over this line.
2: After the tape is in this GENERAL POSITION on the fuselage, again find the EXACT centerline from the motor mount to the horizontal stab. The exact position of this line begins at the top of the lower horizontal stab mount, and ends at a point 1/8 below the top motor mount stick. You can find this point, by placing a piece of scrap wood (1/8 thickness ply suggested) inside the motor mount area, or it is easy to “eyeball” the long measuring stick as parallel to the motor mount.
3: With minimal pressure, use a pen to draw this centerline on the tape exactly. Again, from 1/8 below the bottom edge of the top motor mount stick to the top edge of the lower horizontal stab mount.
Note: Do not remove this blue tape until after the final gluing of the top wing has been completed and the epoxy has fully cured.
ID:	636229   Click image for larger version
ID:	636230   Click image for larger version
ID:	636231   Click image for larger version
Old 03-06-2007, 09:01 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Posted: Mon Mar 05, 2007 1:53 pm Post subject:
Lower Wing Panel Install:
Note: The ailerons are added last, as aligning the top wing will be easier without ailerons to complicate the process.
1: Begin by adding a drop (or two) of thin CA to the wooden alignment dowels that are at the front and rear of the wing roots. Be sure they are glued in well, but just a drop is usually enough. After the CA is soaked in, give that area a shot of CA kicker (or allow a minute to fully cure), and move on to mounting the wing.
2: “Rough up” the two carbon fiber wing tubes with 150 to 220 grit sand paper, to give the glue a good contact surface for adhesion.
3: Next, install one panel onto the carbon fiber wing tubes. Slide the tubes into the wing root, and approximately 1/16 to 3/32 of an inch beyond the ply reinforcement on the second rib. Be sure you slide the tubes beyond their tapered portion. Use thin CA followed by medium CA to glue the tubes to both ply reinforcement plates. Allow thin CA to soak in a second or two, and then add the medium CA. After a few moments, apply CA kicker to the glue joints.
ID:	636233   Click image for larger version
ID:	636234   Click image for larger version
ID:	636235   Click image for larger version
Old 03-06-2007, 09:06 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Horizontal Stab Install:
1: Center the horizontal stab in the slot at the rear of the fuselage. Measure that each outboard tip of the stab is equally distant from the fuselage first. Following that, you should measure from the outboard forward tip of the stab to the rearmost outboard tip on the adjacent wing. Measure several times, and then mark the stab, where it contacts the fuselage on top and bottom.
2: Remove the covering from the center of the stab, approximately 1/16 of an inch INSIDE the marks you made. It is best not to use a sharp knife, but a hot soldering iron, with a pointed tip. Use a metal straight edge as a guide, and slowly move the iron across the covering allowing heat, not pressure, to cut the covering. Simply cutting the covering with a sharp knife can often damage the stab, and almost guarantee a failure in flight during high “G” maneuvers
3: After removing covering from the top and bottom of the stab, prepare some 30 minute epoxy for bonding the stab to the fuselage. Some modelers prefer to use CA for this job, but the additional work time that epoxy allows will be of great benefit. Apply mixed epoxy to the top and bottom of the stab, on the exposed wood. Slip the stab in place (from the rear), and clean up any epoxy that oozes out with rubbing alcohol and paper towels. Realign the stab, measuring again stab tip to fuselage and stab tip to rear of bottom wing. Next, set the stab square to the fuselage, using a right angle, and tape the stab in place with masking tape. As with the wing, check the joint a few times, during the cure process. Measure to be sure the stab has not shifted, and clean whatever epoxy you can find with rubbing alcohol and paper towels. When fully cured (often longer than 30 minutes), remove the tape.
ID:	636237   Click image for larger version
ID:	636238   Click image for larger version
ID:	636239   Click image for larger version
ID:	636240   Click image for larger version
ID:	636241   Click image for larger version
Old 03-06-2007, 09:08 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hinge the Elevator to the Stab:
1: To make this as easy as possible, the 4 hinge locations are pre slotted for you from the factory. Simply slide all hinges into place, checking from top and bottom that none of the hinges have missed the precut slots. After you are content that all hinges are centered in place, flex the elevator at the hinge, just beyond the amount of throw you intend to use for full 3D throws. Add thin CA to the top of the hinge, one drop at a time. Pause between drops for a second to allow the CA to wick into the wood. Five to six drops of CA per hinge is usually enough. Wait a few moments, and then repeat this process to the bottom of each hinge. Never use CA kicker on a hinge. If any CA runs over your covering, it can be removed with Acetone, or fingernail polish remover. Use either sparingly.
ID:	636244   Click image for larger version
RedFishTom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
great, what timing just ordered my kit yesterday.
RedFishTom is offline
Old 03-06-2007, 09:10 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vertical Fin Install:
1: The vertical fin is aligned by making sure there is a straight line along the rear of the fuselage to the rear of the vertical fin. This line is your rudder hinge line. The fin must be centered on the top of the fuselage. After aligning and centering, mark the location where the fin must be mounted.
2: Cut away covering from the top of the fuselage, approximately 1/16 of an inch inside the marks you made. Also, remove the covering from the bottom of the fin, to allow wood to wood contact.
3: The fin is “butt-glued” on top of the fuselage. Mix up a small amount of 30 minute epoxy and coat the exposed wood on top of the fuselage and the exposed wood on the bottom of the fin. Put the fin back in place, center, and align the fin. Use pins or masking tape to hold the fin in place as the glue cures. If using CA, run a bead of medium CA down the center of the wood you exposed on the fin and fuselage. After that, align, center, pin (or tape) and then apply a bead of medium CA around the fin. Allow the CA to soak for a few moments, then apply CA kicker. With either gluing technique, fin alignment must be absolutely correct, and the joint must be very strong. Again, 30 minute epoxy is most highly recommended for this procedure.
ID:	636253   Click image for larger version
ID:	636254   Click image for larger version
Old 03-06-2007, 09:11 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hinge the Fin to the Rudder:
1: Install the 4 pre slotted hinges for the fin and rudder in the same way you installed the elevator hinges. Do not forget to add the two hinges between the lower rudder and the lower fuselage.
ID:	636258   Click image for larger version
Old 03-06-2007, 09:14 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Strut to Lower Wing Initial Install: (No incidence meter required)
Note: If you happen to have an incidence meter, you can use it to set the top wing incidence, but these directions will aid those without such a tool.
1: Test fit the top wing by first assembling the mounting tabs to the struts with the supplied 4-40 x 5/8 bolts and locking nuts. The longer set of strut tabs are for the forward part of the struts. Fit the struts to the top wing (No Glue Yet) and then fit the top wing assembly to the lower wing/fuse assembly.
2: You can now confirm the top wing incidence by measuring from the leading edge and trailing edge of the top wing (at the center), down to the fuselage centerline you drew early in the assembly process. The measurement from the leading edge down to the centerline and from the trailing edge down to the centerline should be the same. Be certain that you are measuring from 90 degrees perpendicular to the centerline, straight up to the top wing leading and trailing edge. Do not remove the blue centerline tape until after the final gluing of the top wing has been completed and fully cured.
ID:	636261   Click image for larger version
ID:	636262   Click image for larger version
ID:	636263   Click image for larger version
Old 03-06-2007, 09:16 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Note: If the wing is not perpendicular to the fuselage, try flipping the mounting tabs around backwards until the top wing is perpendicular to the fuselage. You may also need to sand them on one side to allow the trailing edge to move forwards or backwards (on either side) in relation to the bottom wing.
3: Measure from the rear most tip of the wing to the rear most point on the fuselage on each side. The measurements should be the same for each side. Measure from the leading edge (at the tip) of the top wing to the leading edge of the bottom wing. These should be the same measurement for each side. Also measure from the trailing edge (at the tip) of the top wing to the trailing edge of the bottom wing.
4: Again, the critical measurements that must equal out to build a square biplane are:
• From the middle of the wing leading edge and trailing edge down to perpendicular to the centerline. (Use a 90 degree square and a ruler.)
• Wing trailing edge tip to rear fuselage for each side.
• Top wing leading edge to bottom wing leading edge for each side.
• Top wing trailing edge to bottom wing trailing edge for each side.
5: When you are satisfied with the wing alignment, tighten the bolts holding the strut to the tabs. By tightening the bolts at this point will allow you to remove the top wing and struts, with tabs attached, while keeping very close to the intended alignment. Carefully remove the upper wing and struts from the airplane. Use 30 minute epoxy to mount the strut tabs in the lower wing, with the strut still attached by bolts. (Make sure you put the bottom of the strut in the bottom wing.) Also slide the top wing onto the strut/tab assembly and into place to maintain alignment. Allow the epoxy to fully cure, and then you can remove the top wing, for the next few steps, if you like.
ID:	636265   Click image for larger version
ID:	636266   Click image for larger version
Old 03-06-2007, 09:18 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Landing Gear Install:
1: Mount 2 1/2” foam wheels to the bottom of the aluminum landing gear using 6-32 x 1.25 bolts as axles, washers, and double locking nuts. You will likely have to drill out the plastic wheel hub to do this. Mount the completed landing gear to the fuselage with 10-32 x 1.25 bolts, washers, and locking nuts at the pre drilled location
2: Bend a right angle in the tail wheel assembly torque arm. Mount the tail wheel assembly to the rear of the fuselage with supplied wood screws. You can attach the torque arm to the rudder with a second 90 degree bend and a drilled hole.
ID:	636268   Click image for larger version
ID:	636269   Click image for larger version
ID:	636270   Click image for larger version
Old 03-06-2007, 09:20 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't worry RFT. As I said... In production... It's not like they will be here tomorrow. Build your kit, and consider the ARF as a back up in the future.
Old 03-06-2007, 09:21 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Radio Gear Install:
1: Begin by installing the tail servos. You will need two 12 to18 inch extensions. The length depends on the stock lead length of the servo. Install the extension on each servo by carefully removing the plastic connector housing. Plug each individual connector from the servo into the extension (matching colors carefully), and secure with small heat shrink tubing. This method is smaller, lighter, and more secure than simply plugging the plastic connectors together.
2: Install the top servo first by simply drilling the holes for the servo screws and slide in the servo. Next, install the bottom servo and pull both servo wires to the channel and push them in place in the channel in the bottom of the fuse. Cover over this channel with the supplied matching covering. (Clear tape used for photo.) A one inch wide strip approximately 24” long does a good job. Cut a small 1/8” x 5/16” hole in the bottom of the wing sheeting on the left wing immediately by the fuse and slide the wires in. Seal this hole and the ends of the servo extension wire tunnels with clear silicone.
ID:	636272   Click image for larger version
ID:	636273   Click image for larger version
Old 03-06-2007, 09:23 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
3: Mount the throttle servo to the right side fuselage on two ¼ inch ply/balsa triangle servo mounts. Determine the proper location based on the engine you choose and remove a small amount of covering to make a good wood to wood contact point. After gluing the mounts, you should fuel proof them with thin CA (allowed to soak in a bit) or epoxy. After the fuel proofing glue has cured, install the servo on the mount with rubber grommets (supplied with radio gear) to protect it from vibration. Cut a small hole in the lower wing sheeting and thread the servo wire through. Do not yet seal this hole, as you may use the same hole, to run aileron extensions, if you have chosen to use the top wing aileron servo option.
4: The main radio switch can be mounted anywhere, but the ideal place is on the left side, near the radio hatch. You can also mount the receiver wrapped in foam under this hatch
ID:	636275   Click image for larger version
Old 03-06-2007, 09:25 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
5: Next, add the aileron servo mounting tabs to the aileron servo hatches. First, pre-drill the servo mount tabs for the servo and mount the servo to the tabs, using the rubber grommets included with the radio gear. With the servo arm on the servo, find a location that best allows the servo arm to move freely. Use medium CA to glue the servo tabs to the hatches, and allow them to cure for a few moments, before using CA kicker. Wipe away the kicker residue with a paper towel or tissue, and add a second bead of medium CA to the outside of each mount tab, as a precaution, then use the CA kicker again.
6: Carefully cut away the covering material around the hatches you intend to use for the aileron servo locations. Again, if you are using the top wing locations, the supplied hatches will fit, but you will need to remove the dark covering that makes up the diamonds, from the hatch. You can clean up any covering adhesive residue with a small amount of Acetone or fingernail polish. Use your warm iron to adhere the cut covering inside the hatch openings.
7: The hatch covers are pre-drilled for hatch screws, but the backing plate (inside the wing) may not be. Using a small drill bit (5/64 recommended), and the hatch cover for alignment, to carefully drill the backing plate. Test fit the hatch and screws, and then remove both. Add one drop of thin CA to each hole you drilled, and use a “puff” of breath to clear CA from the open hole, before you allow it to cure. After the CA is fully cured, run the screws back in, and remove them a second time.
ID:	636277   Click image for larger version
ID:	636278   Click image for larger version
ID:	636279   Click image for larger version
Old 03-06-2007, 09:27 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Note: If using the lower wing aileron servo location, skip this next step.
8: If using the top wing aileron servo location, you will need to make a small hole in the bottom of the top wing for servo extensions to go to the lower wing, where your receiver will be located. Use a very sharp hobby knife, or even a Dremel cutter to make a small hole, being careful that only sheeting is being cut. Cut the hole no further forward than where shown, and do not cut the structure inside the wing. Put this hole on the right side of the wing, so that the aileron extensions can also be run through the throttle extension opening (on the lower wing). After the top wing is finally mounted, you can secure the servo extensions to the side of the fuselage with small landing gear straps (not included with this ARF), or any other preferred method.
Old 03-06-2007, 09:29 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Top Wing and Strut Final Install: (No incidence meter required)
Note: For this step, certainly you should consider covering the strut tabs and struts with blue masking tape to aid in keeping the parts clean during gluing.
1: Place the top wing in position, sliding all upper strut tabs into place in the top wing. Recheck the wing alignment measuring from the rearmost wing tips to the rearmost point of the fuselage (Both sides). You may need to sand the strut tabs to allow the top wing to be shifted forward or aft, as necessary, on either side. Reconfirm wing incidence by measuring from the top wing leading edge and trailing edge to the fuselage centerline you drew early in the assembly process. Make sure at this point that all strut bolts are tight, and then remove the wing again.
2: Coat the upper strut tabs and their corresponding sockets with some mixed 30 minute epoxy. Place the top wing back in position and recheck alignment and incidence. As the epoxy cures, recheck this several times. Wipe away epoxy that runs out with paper towels and rubbing alcohol.
3: Again, the critical measurements that must equal out to build a square biplane are:
• From the middle of the wing leading edge and trailing edge down to perpendicular to the centerline. (Use a 90 degree square with a ruler.)
ID:	636290   Click image for larger version
ID:	636291   Click image for larger version
ID:	636292   Click image for larger version
ID:	636293   Click image for larger version
Old 03-06-2007, 09:31 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
4: Bolt the four aluminum cabane strut pieces loosely on one end to the top of the fuselage at the predrilled holes with 4-40 x 3/4 bolts, washers, and locking nuts.
5: The rear strut tabs will need approximately 3/8” cut off the square end to fit to the right depth in the wing. Take two of the scraps from trimming the rear tabs and sand them to 3/16” thick for use in the next step.
6: Place the last 4 tabs in the corresponding sockets and loosely bolt the other ends of the 4 aluminum cabane struts to the 4 tabs with 4-40 x 1 bolts, washers, and locking nuts. Glue the tab pieces you cut away in the last step between the center mount tabs (with thin CA) to keep the tabs from being crushed together when tightening the mounting bolts. Allow the epoxy to fully cure (often longer than the labeled 30 minutes), while the plane remains upside down.
7: Only after the epoxy has fully cured (often more than the labeled 30 minutes), remove all of the all blue tape, and turn the Boxxer over, on its back.
ID:	636295   Click image for larger version
Old 03-06-2007, 09:32 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hinge the ailerons to the wing:
1: Hinge the pre slotted ailerons to the pre slotted wings with the (supplied) 5 hinges per wing panel, as you did for other surfaces. Be cautious that you put the ailerons in correct position. The solid yellow ailerons go on the bottom wing and the ailerons with trim color go on the top wing. Ailerons taper smaller towards the wing tip.
ID:	636297   Click image for larger version
Old 03-06-2007, 09:35 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Engine Mounting:
1: Mount the engine using 6-32 bolts, washers, and locking nuts. Induce about two degrees of right thrust (2 washers or offset plate, not included, under the front lugs) and check there is zero up or down thrust. Mount your prop and spinner as well.
ID:	636299   Click image for larger version
Old 03-06-2007, 09:38 AM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a pic of the custom made carbon fiber control horns. These are installed by cutting a small slit, in the correct spot, and shooting in a little thin CA along side the horn. I'll get to these today... Then pushrods and linkages...
But first, I can't help but notice that all of the American Flags in my neighborhood are hanging straight down. It's time for a foamy flight...
I'll be back to finish...
Old 03-06-2007, 04:09 PM
CopperheadAV
CopperheadAV's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You do a mean build thread Tailtwister!!!
I want one!!!!
CopperheadAV is offline
Old 03-06-2007, 08:16 PM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Final steps:
1: Assemble and mount the fuel tank with your preferred method. The supplied cable ties are shown here. Keeping the tank near the CG will minimize the CG shift, as the tank drains during flight.
2: The Boxxer ARF includes Carbon Fiber control horns. To use them, first scuff up the contact point of the horn with sandpaper. Second, cut a small slot, in an appropriate location. Use CA to install the horn, allowing plenty of time for the CA to wick into the balsa fibers. The rudder horn is shown here.
3: Install the aileron interconnect horns by measuring 10.25 inches from the outboard tip of the aileron at the trailing edge, and mark that location. Center the horn so that the horn points to the rear of the aileron, and the pivot holes are over the trailing edge. One set of horns will go on the underside of the top aileron, and the second set will go on the top of the lower aileron. The longer two of the supplied push rods are for this connection.
ID:	636804   Click image for larger version
ID:	636805   Click image for larger version
ID:	636806   Click image for larger version
ID:	636807   Click image for larger version
Old 03-06-2007, 08:17 PM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Balancing the Boxxer:
1: The Center of Gravity (CG) of the plane should be 1” forward of the trailing edge at the center of the top wing. Check this by placing a finger under that spot and lift the plane. The plane should hang level in all directions.
2: You can change the way the plane balances, a bit, by moving internal components. Also, prop and spinner selection can affect the CG. If this does not create enough change, then adding lead may be necessary to achieve the proper balance.
Old 03-06-2007, 08:21 PM
TailTwister
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My set up is:
All supplied OMP hardware
Saito 82
15x4W APC
Spin Rite Aluminum spinner
Spektrum AR7000
Hitec HS 225 for throttle
Spektrum DS 821 servos for control surfaces
5 cell 700 mah NiCad
My ready weight is 4 pounds 12 ounces. I'm going to swap out to a Pro Zinger prop, and change the spinner out for a spinner nut. That will likely cut 3 ounces right away. A lighter pack might be in my future as well.
