Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Swany Mojo 40 ARF?
Reply
Old 12-23-2007, 09:41 AM
  #51
Flyboy1958
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Swany Mojo 40 ARF?
I was wondering about the tail wheel as well. I know a guy at the field with a Mojo 40 and he just uses a 2-56 control rod sticking out the bottom of the rudder and bent at the end. It works perfect, steers the airplane around and saves on the weight with no wheel or heavy wheel collor.
Flyboy1958 is offline
Old 12-24-2007, 02:50 AM
  #52
AKFireMedic
AKFireMedic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A 40 or 60 size Dubro wheel works great. You can just leave it castering as the rudder is large enough to turn the plane around without a problem. Also, solder washers onto the tail wheel wire to hold the wheel in place instead of wheel collars and you'll save a little weight.
AKFireMedic is offline
Old 01-02-2008, 06:14 AM
  #53
perkinsm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good ideas guys,,,,Thanks
perkinsm is offline
Old 01-06-2008, 08:34 PM
  #54
Ricky Blade
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i was givin a mojo 40 with no papers. how can i get building instructions, layout, equipment requirments, plans and cg info? you know, the info that's in the box when purchased new. please help, ricky.
Ricky Blade is offline
Old 01-06-2008, 08:36 PM
  #55
Flyboy1958
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Download it online at swanyshouse.com
Old 01-06-2008, 10:41 PM
  #56
PaulSwany
My Feedback: (45)
PaulSwany's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can get the instructions here: http://www.swanyshouse.com/mojo/mojo...nual_small.pdf
PaulSwany is offline
Old 01-06-2008, 11:13 PM
  #57
evan-RCU
evan-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul, I'm looking for a .32 size profile ARF, any recommendations?
evan-RCU is offline
Old 01-07-2008, 05:55 PM
  #58
garygee
My Feedback: (9)
garygee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
talk to me paul...when are the mojo arf's going to be back in stock =(
garygee is offline
Old 01-07-2008, 09:16 PM
  #59
Flyboy1958
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just bought the kit, it's a really easy build and a lot of fun. It only took me a couple of hours a day for about a week, to build and finish the whole thing.
Old 01-17-2008, 02:25 PM
  #60
perkinsm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I started to assemble mine today. I got the motor mount epoxied to the CF tube and from what I can tell, it slides through the front of the wing. The fit is VERY tight. I dont want to force it. Any suggestions?
perkinsm is offline
Old 01-17-2008, 03:06 PM
  #61
PaulSwany
My Feedback: (45)
PaulSwany's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can sand a little off the wing pocket for clearance... You might also check to see if all the epoxy that's ozed out has been removed...
Old 01-17-2008, 03:11 PM
  #62
perkinsm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Paul,, I'll give that a try
perkinsm is offline
Old 01-17-2008, 10:07 PM
  #63
perkinsm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got some work done on my Mojo tonight. Coming out pretty good !!!
ID:	853810   Click image for larger version
perkinsm is offline
Old 01-17-2008, 10:49 PM
  #64
PaulSwany
My Feedback: (45)
PaulSwany's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That looks really sweet! Is that one of the ARF's or is it kit built?
Old 01-18-2008, 04:51 AM
  #65
perkinsm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul - It's one of the ARF's. I noticed one of the other Bro's plane that I liked and was lucky to be able to send him the ARF and he stripped it and re-covered it and did some air brush highlights.
He did an awesome job,,
perkinsm is offline
Old 01-18-2008, 09:09 AM
  #66
rtn9105
My Feedback: (35)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What's the reason for separating the top and bottom fuse halves?
rtn9105 is offline
Old 01-18-2008, 10:47 AM
  #67
PaulSwany
My Feedback: (45)
PaulSwany's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rtn9105
There is a fiberglass tube between the two halves that extends from the motor mount to the rudder post. It's the way it's built.
Old 01-18-2008, 10:55 AM
  #68
craigteffe
My Feedback: (24)
craigteffe's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is the blue all airbrushed on? What kind of paint do you use? How do you prep the surface of the covering?
Did you make your own pattern or is there somewhere that i can get the pattern, I am asking because I'm getting ready to cover a OMP Hybrid Edge and this is the way i've been wanting to cover my plane except with Yellow and red scheme.
Thanks for your help in advance.
craigteffe is offline
Old 01-18-2008, 11:53 AM
  #69
rtn9105
My Feedback: (35)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry I wasn't clear in my question. In the pictures above the bottom half of the fuse isn't there. The top and bottom halves of the mojo fuse are normally joined at the rudder and glued to the wing in one piece. Why has the fuse been cut into two parts and is now being glued to the wing/motor mount separately? Is there any advantage / disadvatage to assembling the plane in this manner?
rtn9105 is offline
Old 01-18-2008, 12:01 PM
  #70
evan-RCU
evan-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul, is there any plans to ARF a .30 sized Mojo or Taco?
evan-RCU is offline
Old 01-18-2008, 12:08 PM
  #71
PaulSwany
My Feedback: (45)
PaulSwany's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not at this time.
Old 01-18-2008, 12:13 PM
  #72
evan-RCU
evan-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, any idea of an ARF of a 30 size fun fly like these, Menace, Minus, or lil' Rippy?
evan-RCU is offline
Old 01-18-2008, 03:47 PM
  #73
AKFireMedic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't think it's been cut. It just hasn't been put together with the rudder post yet.
Old 01-18-2008, 06:03 PM
  #74
perkinsm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Heres a few more pics of the almost completed airframe. Should finish that part up tomorrow.
Graig - To answer some of your questions. The covering is Ultracoat in pearl white and pearl purple. Like I mentioned before, another BRO covered it and did the airbrushing, so I cant answer some of your questions,,, Sorry.
Paul - I wanted to comment on the engineering, etc of this plane: Of all the planes I have put together (All ARF's), this is the best engineered, thought out, that I have assembled to date. The CF tube concept from motor mount to Rudder is a fantastic design for strength and weight. It was VERY easy to put together. I have maybe 2 to 2 1/2 hours assembly time to get it to the point in the attached pics.
ID:	854366   Click image for larger version
perkinsm is offline
Old 01-18-2008, 06:10 PM
  #75
perkinsm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Forgot to post a pic of the Rudder. I have to fix that gap, its HUGE ,,,, I just noticed it when I took the pic.
perkinsm is offline
