Scratch built profile for Magic wings.
My Feedback: (9)
AZ
From an earlier thread that I screwed up the images:
What to do with a spare set of Magic wings taking up space in the shop? Add some wood and a few small parts and Poof! A new model.
The fues is built up from 1/4 inch square sticks of balsa and hard wood sandwiched between 1/8 light ply. Tail group is 1/4 inch balsa with a stick of hardwood in both the vert and horiz for a spar.
My Feedback: (9)
AZ
More Build-Up Pics 7
Coming Together!!
Wings were badly warped after a year in the garage in a 120 degree Arizona heat. I had to strip and steam them. If your wife wants one of those new garment steamers that are popular now. BUY IT FOR HER!!
I'll post some more after I finish it up. Still have to mount the wings and ailerons. And install radio gear and maybe beef up the gear.
My Feedback: (54)
PA
Thats really good Idea and looks good! Let us know how it flies.
My dad and I both have a magic and love them. He has an OS LA 46 with a Macs pipe, and I have a Webra 50 wiht a Macs. I use 40% nitro fuel on mine!
My Feedback: (9)
AZ
ALL DONE!!
Ready to fly. Had to add 3oz to nose to balance close to the Magic marks. Should be able to remove them after I get used to this. I flew my Magic about an inch aft of the stated CG. Added a second set of wires to the gear, 'ala Magic. Used shrink wrap to cover crappy welds. Wont waste my time trimming it until it survives first flight and I know it flys. HERE GOES:
Fired it up, set the throttle, did a range check...UH OH...
My Feedback: (9)
AZ
ABORT!
It went ape sh-t during the range check at about 30' with the engine running. I know it's the receiver. It's the one that came out of my Magic. The last flight of the Magic I almost lost it until it got back over the runway. Turned out the fues was full of fuel and the receiver was floating. I took it apart and cleaned it with alcohol but I guess it's shot. Maybe next weekend!?
My Feedback: (9)
AZ
Wings
I toyed with the idea of removable wings, something along the same lines as a Sig SE. Or thru-bolt them with access hatches under the wing. But in the end I chickened-out and just epoxied them on using the stock Magic joiner. I use a method I've done on profiles before. One wing at a time I coat the joiner and pocket and the rib (all except about a quarter size area in the center of the rib) with 2 hour epoxy. Then place a dollop of 5 min epoxy in the center of the rib, slide it together, line up the marks and hold by hand until the 5 min epoxy goes off. Then clean up the ooze with alcohol and it makes a nice bead.
